Am I One Tooth Off?
Old Dec 26, 2003 | 05:30 PM
Paul L's Avatar
Paul L
Default Am I One Tooth Off?
Look carefully at this picture. Before winter storage I set the timing at 8 degrees BTDC at about 600rpm. That is with a static timing light. I was looking for 10 degrees but the vacuum advance unit ran up against the manifold. Am I one tooth off with the distributor?
Old Dec 26, 2003 | 06:46 PM
rainman69's Avatar
rainman69
Default Re: Am I One Tooth Off? (paul67)
Lars is the man who could tell you for sure, but that looks one tooth off to me. The vacuum canister on the distributor should point to the #6 exhaust port.
Old Dec 26, 2003 | 06:49 PM
1979toy's Avatar
1979toy
Default Re: Am I One Tooth Off? (rainman69)
I agree with Rainman, it looks like you are off a bit.
Old Dec 26, 2003 | 06:52 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Re: Am I One Tooth Off? (1979toy)
You need to pull it out and restab it you are off a tooth or two :D
Old Dec 26, 2003 | 07:27 PM
1979toy's Avatar
1979toy
I forgot one other thing. Your mechanical advance could be stuck in the full advance position.
[Modified by 1979toy, 7:10 PM 12/26/2003]
Old Dec 26, 2003 | 08:15 PM
Paul L's Avatar
Paul L
On the Lars suggestion, I have his C2 kit. I may have made a mistake when I put that aluminum intake on last summer. Lars' instructions are pretty detailed and plain reading. I will follow them when I see the car in the spring. Sorry to bother you fellows....
Old Dec 26, 2003 | 10:39 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
You could try shifting the wires on the cap. It sounds more like you may be a wire off on the cap.
Old Dec 26, 2003 | 11:37 PM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Do we have a new one-liner for the list?
"Paul? His distributor is one tooth off!" :D
Looks off a tooth to me, too if that's only 8 deg.
Old Dec 26, 2003 | 11:58 PM
MotorHead's Avatar
MotorHead
Default Re: Am I One Tooth Off? (ddecart)
How bout them leafs :lolg:
Old Dec 27, 2003 | 07:53 AM
Paul L's Avatar
Paul L
Dave,
Yes I just ran out of adjustment room as the can hit the manifold. I just picked up an advance timing light so I will get things done properly in the spring with the Lars kit.
As to teeth, I may be a few short of a full set;).
Old Dec 27, 2003 | 07:54 AM
Paul L's Avatar
Paul L
Default Re: Am I One Tooth Off? (MotorHead)
Go Sens Go!
Old Dec 27, 2003 | 08:52 AM
Dave62's Avatar
Dave62
Paul,
Actually the distributor looks to be 1/2 tooth off to me. This is caused by the gear (cam gear) being in the wrong position on the distributor shaft. The cam gear has a dot on it...the dot should be in the same position as the tang on the rotor button. The gear can only be put on the shaft in two positions. If it is opposite of what is correct the distributor can not be put in exactly the correct position. Check this when you pull the distributor.
Dave 62 :seeya
Old Dec 27, 2003 | 10:11 AM
Paul L's Avatar
Paul L
Default Re: Am I One Tooth Off? (Dave62)
Thanks Dave. I will certainly check that. I pulled this pic off the internet. It shows the vacuum can in what I believe is a correct position.
I learned the dot trick when I rebuilt a 1979 distributor last year. Why I did not check that when the work was being done on the 1967 last summer is beyond me. Sometimes I marvel at my stupidity.
[Modified by paul67, 10:18 AM 12/27/2003]
Old Dec 27, 2003 | 10:17 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
:withstupid:
Old Dec 27, 2003 | 10:34 AM
Tom Johnson's Avatar
Tom Johnson
Lars brought to my attention that the oil holes in the distributor shaft should line up with the oil holes in the engine block.
Old Dec 27, 2003 | 12:21 PM
The Money Pit's Avatar
The Money Pit
Definately off a tooth or two.Mine sets in the block with the front two towers on the cap parallel to the carb mounting bolts.I run 15 degrees in the distributer,but can easily pull it down to 8 if I want.Just line up the zero mark on the balancer and then pull the distributer cap to see where the rotor is pointing now.Then pull the distributer out and as it leaves the cam gear,note how much it turned from the fully inserted position.Take a long flat screw driver and turn the oilpump drive shaft to the desired final position,and set the distributer back in with the additional advance(The difference between the rotor position fully engaged with the cam gear vs. the position the rotor was in when the gear left the cam .It may take a try or two,but you should have no trouble correcting this.
By all means do not rewire the cap to compensate,as someday down the line,Bubba will set the timing or change the plugs and have a heck of a time getting it to run.
Old Dec 27, 2003 | 03:22 PM
Paul L's Avatar
Paul L
Default Re: Am I One Tooth Off? (The Money Pit)
I think between Lars' paper and your advice I have this sorted out. Keep in mind my car is in storage so this is a spring project. Thanks to all for the comments.
Old Dec 27, 2003 | 08:23 PM
killain's Avatar
killain
Oldtimer
Hay Paul, There's a really good article in 'Corvette Enthusiast' Magazine, August 2003, page 68 by John Hinkley that deals directly with the same exact problem seems they couldn't get the timing set without the body of the distributor hitting the manifold, which is when they found out the gear on the bottom was on 180 degrees out. The car will run perfect, but you have to twist the distrubutor way around to get the timing set at the right spot. He says it's a very simple mistake to make when doing distributor work.
Old Dec 27, 2003 | 08:40 PM
Paul L's Avatar
Paul L
Default Re: Am I One Tooth Off? (killain)
Thanks for that! I will work this thing out. I have enough hints/suggestions now. It seems so simple....
To Am I One Tooth Off?
