Metal Spring Height
Changed to 8" bolts today. Now: both fronts are 28 1/2" (good), driver rear 28 7/8", pass rear 29 1/2". She dropped 1 1/2". Not where I want her but at least it is not vibrating like it was at the higher height.
Question: On the 8" bolt, there was no hole and cotter pin. There is only the plastic ring inside the nut. Is this sufficient to hold it on?
[Modified by Dk Met Grn 80 L82, 12:07 AM 12/27/2003]
(my same old rant... re-hashed)...
As mentioned before, the replacement springs (composite and or steel) available to us are built on a "one load height fits none" basis. Possibly this is due to a conservative approach to manufacturing. . . "better too much arch than too little" eh!?!??
I'm sure that some customers actually receive a spring that is fairly close to having the proper load height due to random variances in the manufacturing process.
Different taste in overall stance plays a role too. Some people may like a slightly taller stance. I prefer a lower stance. Something a bit closer to the minimum curb target height specs. One opinion is not necessarily better than the other, just different.
Based on the GM height specifications for my '80 Vette, http://temp.corvetteforum.net/c3/miker//ride_height.jpg
My ride height in the rear is currently:
104% of MIN, 97% of TARGET, and 90% of MAX.
My ride height in the rear prior to installing longer bolts was:
115% of MIN, 106% of TARGET, and 100% of MAX.
GM allowed a surprisingly large span (~2.3") between MIN and MAX. To me it's the difference between that 4x4 look and that "just right stance".
And yet another problem I had while riding at 100% of MAX ride height spec was the poor geometry of my sway bar end links. You can see the difference in this picture:
I certainly don't claim to be an expert on springs but like most anyone, I can tell when parts aren't made correctly. We've all seen plenty of this one size fits none crap with Corvette re-pop parts.
(re-hashed RANT OFF...)
Spring related information/definitions found at: Eaton Springs tech info site http://www.eatonsprings.com/tech%20infro.htm#FREE ARCH
Load Height = how much arch is in a leaf spring when there is a normal load on the spring.
I have heard that after releasing tension on the leaf spring, you have to ride around a bit and retorque a few times to get the spring level again. Any truth to this?
That's too tall for my taste but if you like the way it looks, and rides, you are DONE! Congratulations! Time for the next project.
:thumbs:
