G Tech Pro for Christmas!
Old Dec 27, 2003 | 01:40 PM
Chuck Harmon's Avatar
Chuck Harmon
Default G Tech Pro for Christmas!
It's been raining the past two days, but was still able to play a bit with the G Tech in the Z. It is able to read RPM's without wires, amazingly accurate. It has a shift light you can program to whatever rpm you want. Using a 6900 shift point, the G Tech starts lighting the 1st of 4 lights at 6400rpm. Perfect shift point to avoid the rev limiter if I shift on this first light. There is no mistaking this light even in daylight. The wheel hop I got on my 1-2 and 2-3 shifts suggests my shocks need replacing with something a bit stiffer. But it is sure nice not to have to compensate for tach lag or attempt to read the little white shift light on the HUD.
Using a 3400 total vehicle weight showed a 344hp max in 2nd gear once everything hooked up. This is very close to the 350rwhp I measured on the chassis dyno. I hope to get the car weighed so that I can use a more accurate number, but I think I must be pretty close.
Chuck
Old Dec 27, 2003 | 01:55 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Default Re: G Tech Pro for Christmas! (Chuck Harmon)
Those are fun little dudes aren't they?
I used mine a lot when I had the 427 in it and it was very accurate. I also tried it at the track in the C-4 and it was within .03 or so over 5 runs compared to track ET slips. That's pretty decent for something stuck on the windshield!
The 427 chassis dyno'd at 423 RWHP and the G-tech showed 417, once again pretty close!
JIM
Old Dec 27, 2003 | 10:13 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Re: G Tech Pro for Christmas! (427Hotrod)
I must be doing something wrong or mine doesn't work properly. I bought it brand new. Mine is consistently 100HP below my chassis dyno numbers. How are you guys doing it ?
BTW 344HP on the GTech is probably bang on if you got 350HP on a chassis dyno. The chassis dyno numbers are always going to be a little higher as there is no resistance from the air.
Same goes for the 423HP to 417HP
[Modified by MotorHead, 9:38 PM 12/27/2003]
Old Dec 27, 2003 | 11:51 PM
gdh's Avatar
gdh
Default Re: G Tech Pro for Christmas! (MotorHead)
geez I forgot I had one, last time I used it was with MotorHead to check and see if his was working properly - scarey day when I saw your vette fly by then cut out just before that big curve. :eek: I think mine read out either 283 or 287 before we quit.
[Modified by gdh, 11:53 PM 12/27/2003]
Old Dec 28, 2003 | 12:32 AM
427Hotrod's Avatar
427Hotrod
The only thing that really affects it is the weight you enter. Make sure you have an accurate weight including you and it should work.
I figure anything that you plug into a cigarette lighter and stick on the W/S that gets that close is pretty decent!
JIM
Old Dec 28, 2003 | 01:22 PM
PRNDL's Avatar
PRNDL
Obviously this is the new/improved/upgrade model. How the heck does it do that? I guess the same way a dwell meter reads rpm when attached to the coil, but this thing is plugged into the cigarette lighter.... can somebody explain this? (pls speak very slowly... :lol: ) MJ
Old Dec 28, 2003 | 02:55 PM
Clink69's Avatar
Clink69
Default Re: G Tech Pro for Christmas! (MNJack)
Obviously this is the new/improved/upgrade model. MJ
I know mine can't do that, I have the cheap $100 one.
Old Dec 28, 2003 | 03:28 PM
Chuck Harmon
I think it has a microphone that reads my lips while I lip sync to the engine. The inside of my windshield has always gotten dirtier faster than the outside.
The other possibility may be that it can detect the interference you can hear in your radio if you have a bad set of plug cables or you don't use resistor spark plugs. It asks you to hold 4000rpm and push the button, then it asks for you to hold 2000 rpm and push the button. This allows it to know whether you have a 4, 6, 8, 10, or 12 cylinders.
The lighter the weight you list for the car, the lower the hp reading will be. I used 3400 pounds for the Z. 3118 for the car plus 175 for me plus 100 pounds for gas.
Chuck
Old Dec 28, 2003 | 08:22 PM
Shark Racer's Avatar
Shark Racer
You got the G-tech COMP you mean. ;) Those are awesome toys. I want one really bad!
Guess I'll have to settle for Tom's pro. I've had it in the back of the vette ever since we did that barbeque at your house!
How far along is the L-88?
-Steve
PS I got a lot of tools, a new jack, and a timing light for x-mas!
Old Dec 28, 2003 | 08:53 PM
78 Vette's Avatar
78 Vette
Default Re: G Tech Pro for Christmas! (Pacin'California)
I got one last Christmas its a cool tool. Ran a 12.90 with 3.08 rear gears putting in 3.70 tomorrow.
To G Tech Pro for Christmas!
