Hurst Shifter Handle Replacement
Old Dec 28, 2003 | 12:55 AM
standup's Avatar
standup
Default Hurst Shifter Handle Replacement
....Just an FYI for those who have a Hurst shifter but don't like the handle.....
.......I'm not talking about the linkage here, but I've found the looks of the Hurst handle and even its performance is less than adequate.....when I bought my Vette, I found it was too long a throw to third, and after 8 months, I found myself shifting from the middle of the handle instead of on top to compensate......the replacement stock handle definitely looks and feels/works better.......
.....The replacement handle for the Hurst shifter is available from supporting vendors.......
The repair can be done without removing the console, but you do have to remove the trim plate and upper boot.......it is simply two bolts that hold it in place....so all you need is two combination wrenches and a good amount of patience, 'cause it's slow with the console in......
I removed the Hurst shifter with the console in, but I bolted the new handle on with the console removed......while I was at it, I also replaced the lower shifter boot......the rubber had perished and I wondered if this was excessive to replace a part that wouldn't be seen....but the new boot actually reduced engine smells and heat........
Here's some before and after pics:
BTW, the reverse lockout on this handle is non functional, although it does have the spring mechanism and moves if you pull it up.....kinda cool :)
Hope this helps :cheers:
Old Dec 28, 2003 | 01:05 AM
RHD '68 L89's Avatar
RHD '68 L89
Default Re: Hurst Shifter Handle Replacement (standup)
I did a similar thing with the Tremec shifter except I used an original shifter I got at Carlisle for the job. Makes it look ridgey didge but I have 5 speeds and the shifter comes out of the wrong side of the console.
P.S. I still can't afford to fly you and the missus over much less the accomodation at Crown Towers.
:D :D :D
:cheers:
Old Dec 28, 2003 | 06:33 PM
standup's Avatar
standup
Default Re: Hurst Shifter Handle Replacement (RHD '68 L89)
:D :D :D
:cheers:
I'd like to see a pic of that......
Old Dec 28, 2003 | 07:17 PM
PROSOUTH's Avatar
PROSOUTH
From: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
I like this, it looks very good.
I saw these listed on E-bay for several weeks and then they quit listing them for auction. Where is the best deal on one of these available at? I need to go ahead and get one to be ready for my installation. Thanks, Jim
Old Dec 28, 2003 | 10:58 PM
standup's Avatar
standup
Default Re: Hurst Shifter Handle Replacement (PROSOUTH)
I paid $93 USD at Ecklers.....I didn't shop around, so I don't know if it was a deal or not......also there's a different part number for 77-81 Vettes :cheers:
Old Dec 29, 2003 | 02:06 PM
WESCH's Avatar
WESCH
....BTW, the reverse lockout on this handle is non functional, although it does have the spring mechanism and moves if you pull it up.....kinda cool :)
Wow, didn't know this. Thought it's rigit, one piece construction.
This is on my due list as well to get the car more original looking.
Only problem is, my 68 needs a chrome ball, not a black ball.
They offer up to 67 with chrome ball and from 68 upwards with black ball.
The 67 shifter doesn't fit. :mad
Pls let me know the ECKLERS order number.
Gunther
[Modified by WESCH, 1:07 PM 12/29/2003]
Old Dec 29, 2003 | 03:44 PM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
Default Re: Hurst Shifter Handle Replacement (WESCH)
I agree the "replacement" handle looks much better with the Hurst Shifter. Here is mine:
EDIT: Although the reverse lock-out is non functional getting the Hurst Shifter into reverse is a trick. Really tight on my car. I have always assumed Hurst intended it to be that way.
[Modified by OHSIXX, 3:54 PM 12/29/2003]
Old Dec 29, 2003 | 06:12 PM
standup's Avatar
standup
Gunther
The part number for the handle I bought is Part# 26836, and is supposed to be for '68-'76.......
Ecklers also have a chrome **** Part# A2131 for 64-68 Vettes.....this may fit the handle.....you could ask Ecklers if it will fit or take the risk.....it's $16 for the chrome ****.........:cheers:
Old Dec 29, 2003 | 06:56 PM
standup's Avatar
standup
Default Re: Hurst Shifter Handle Replacement (OHSIXX)
I suppose it could be something in the linkage.....but you might want to check if the handle is binding against the boot and trim plate....a slight adjust in the shifter console might be required......just a thought..... :cheers:
To Hurst Shifter Handle Replacement
