Fuel Vapor Canister ???
Old Dec 29, 2003 | 09:07 AM
mvftw's Avatar
mvftw
Default Fuel Vapor Canister ???
On my '78 I have 3 hoses coming out of the canister. One is small and goes to the manifold or thermostat 'T'. I have disconnected and plugged that one already. One is big and tee's off with the PCV. I want to plug that one and run the PVC direct into the carb.Would that be OK? The last big one goes directly into the carb, that one I will leave hooked up. That one hose should be enough to vent right?
Old Dec 29, 2003 | 11:52 AM
Fleetwood's Avatar
Fleetwood
Default Re: Fuel Vapor Canister ??? (mvftw)
On my 79 cannistor I have one hose that comes from the fuel tank vent,one bigger one that goes to the large pipe on the front right of the carb,& then the rest are plugged.The pcv hose is not connected to the cannistor,& runs from the pcv valve to the pipe on the front left of the carb.Thats all I have.I remember there was a lot of issues with this a while ago,maybe someone will chip in.
Neil.
Old Dec 29, 2003 | 11:54 AM
mvftw's Avatar
mvftw
Default Re: Fuel Vapor Canister ??? (Fleetwood)
That's the way I want to run it, with only the large hose that goes in front of the carb. It should be Ok...
Old Dec 29, 2003 | 12:14 PM
Fleetwood's Avatar
Fleetwood
Thats the way mine runs at the moment,& I don't have any problem. :yesnod:
Old Dec 29, 2003 | 01:00 PM
l2vette's Avatar
l2vette
Just a word of caution, change your gas cap to the vented type as used on the 68 and 69's.
:cheers:
Old Dec 29, 2003 | 01:35 PM
mvftw's Avatar
mvftw
Default Re: Fuel Vapor Canister ??? (l2vette)
l2vette, even though I still have the one large hose connected to the carb.
To Fuel Vapor Canister ???
