Cooling lines Wrench?
Old Dec 30, 2003 | 05:36 PM
koni9's Avatar
koni9
Default Cooling lines Wrench?
Is there a special wrench or socket for the tranny/Rad cooling line fittings??
I am starting to round the one fitting off?
:confused:
Old Dec 30, 2003 | 05:51 PM
OldSchool's Avatar
OldSchool
Default Re: Cooling lines Wrench? (koni9)
It's called a "line wrench" Sears sells them.. I ended up buying the set since it was only a few dollars more than the individual wrench!! Used for brake lines also...Good luck :smash:
Old Dec 30, 2003 | 07:07 PM
PigPen's Avatar
PigPen
Flare Nut Wrench. Sears and elsewhere. I use nothing else on flare nuts. I did round a brake line fitting even with the wrench only once, but they are a must have item.
To Cooling lines Wrench?
