Flywheel torque rate question
Old Dec 30, 2003 | 08:23 PM
garandfan's Avatar
garandfan
CI 5-6-7-8-9 Veteran
Cruise-In 7 Car Show Winner
Default Flywheel torque rate question
I'm getting ready to drop the motor and tranny back in the beast. I'm putting a steel lakewood bell housing on, need to pull the flywheel to put the front plate on. What is the torgue spec on the flywheel bolts? ZZ4 motor
Frank
[Modified by garandfan, 7:24 PM 12/30/2003]
Old Dec 30, 2003 | 08:33 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Re: Flywheel torque rate question (garandfan)
65 ftlb
Old Dec 30, 2003 | 08:40 PM
garandfan's Avatar
garandfan
Default Re: Flywheel torque rate question (1970 Stingray)
Thanks to the kind Sir from W. PA
Frank
Old Dec 30, 2003 | 09:16 PM
Denmech's Avatar
Denmech
btw, don't over torque as it will crack the end of the crank and cause an oil leak.....chevy service bulletin.
To Flywheel torque rate question
