TRAILING ARM REMOVAL?
Old Aug 29, 2012 | 07:40 PM
lvmyvt76's Avatar
lvmyvt76
did you go thru the rear end while you have it out, or just thinking new paint will fix it?
Old Aug 29, 2012 | 10:13 PM
STL 71 C3's Avatar
STL 71 C3
I mixed transmission fluid and acetone in a spray bottle, then kept the bolt ans shims wet for a week or so. (I was waiting on parts so not in a hurry)
I pulled the bolts out with needle nose pliers....real easy to come out.
Originally Posted by '75sting
IF THE BOLT WILL NOT COME OUT OF THE BUSHING TO REMOVE THE ARM WHAT SHOULD I DO? I'VE SOAKED IT WITH PB BLAST AND TAPPED ON THE BOLT AND STILL NOTHING. I NEED SUGGESTIONS IF YOU GUYS HAVE ANY.
THANKS'
LEE
