81 - Horn doesn't work
Old Jan 5, 2004 | 11:54 AM
Scorn's Avatar
Scorn
Default 81 - Horn doesn't work
This is my first Vette and I noticed I have no horn. Any idea on how hard this will be to replace? Thanks in advance for any helpful answer.
Old Jan 5, 2004 | 12:42 PM
JBR's Avatar
JBR
Default Re: 81 - Horn doesn't work (Scorn)
I have a 78 with a walnut steering wheel, no horn contacts or anything and I'm still acquiring parts and info. 1st thing, find a drawing of the steering column that you have. Your GM dealer should be able to photo one for you. Then find out what parts are missing. :cheers:
Old Jan 5, 2004 | 01:16 PM
Fast81's Avatar
Fast81
Most likely its something broken in your steering column. Just order the horn rebuild kit from Corvette Central, you get all the parts for around $30. Don't do the job 3-4X replacing a part at a time like one idiot I know :rolleyes:
Old Jan 5, 2004 | 01:31 PM
Biker's Avatar
Biker
Default Re: 81 - Horn doesn't work (Fast81)
Before you go tearing into the steering column horn wiring, check obvious things like the fuse. If it's good, disconnect the horn wire and connect a volt meter. Then have someone depress the horn switch at the wheel. If you've got power at the wires, then the horn is defective. If you don't have power, work backwards, checking for power in the wires back toward the switch. Be sure to check the horn relay, too.
Old Jan 5, 2004 | 02:42 PM
Scorn's Avatar
Scorn
Default Re: 81 - Horn doesn't work (Biker)
Many thanks. If I don't get this fixed, I can't get my inspection stickerin Texas. Unless, of course, I go to a "Vette guy" who works at a place to get inspections. :blueangel:
Old Jan 5, 2004 | 03:43 PM
Jim Shea's Avatar
Jim Shea
The following is a link to a paper that is posted at the Corvettefaq websight. The paper will help you diagnose your horn problem.
http://www.corvettefaq.com/redir.asp?site=649
To 81 - Horn doesn't work
