Looking for an 80-82 6 Link Setup
Toe is controlled by the shims on the front arm mount and the arc that the 1/2 shaft and the arm/hub assembly move over, the extra link will not add anything, it may look truck but if you have something fixed with 2 points a 4rd point won't control anything unless one of the other 2 is "loose"
I COULD see this work if they have the stock bushing sjust loose in there so it slides over the bolt, no shims. Then you CAN use this to set toe, it will be easier to adjust but the level of toe contol remains the same as stock, because the arm hinges at 1 point you still have the inherent toe control problem present in the C3 suspension.
That car is a german 82 with LS1 done by ACP, the people that also do the brembo brakes and koni coil over setups.
[Modified by Twin_Turbo, 4:29 AM 1/10/2004]
I don't think that any of the 6 link kits except the Guldstrand will control the toe. They all use the stock trailing arm for that. The only advantage to the 6 link fabbed by Mr. Taylor and others is the ability to adjust the camber and control the trailing arm in the event of a halfshaft failure. Installing a spacer on the center mount for the lower control arms, or using the VB&P center mount, will reduce the amount of camber change.
Halfshaft, or U-joint, failure is a very real problem for anyone drag racing a C3. The upper link of a 6 link will keep the wheel contained in a more or less normal position in the event of a failure as it removes the halfshaft as the upper control arm.
The '80-'82 rear suspension differs very little from the earlier C-3. The main issue is the aluminum batwing does not allow the same method of mounting the upper center link to the chunk. Do a search and you will find many ideas and methods of approach to this. I have decided to put in an upper 2x2 crossmember to attach the upper links to. Norval has an older style and used this same method on his. It is really much easier and more stable to do so IMHO.
It may not be a perfect suspension package but it is definitely an improvement over the OEM halfshaft upper control arm style and removes the constant beating of the carrier from the yokes. As I said do a search, there are many pages of discussion on this topic. Jim
