what would cause total power lose while driving?
Old Jan 8, 2004 | 05:15 PM
bhmyers's Avatar
bhmyers
Default what would cause total power lose while driving?
I have a buddy that has a 75 and he told me on several occasions while driving he looses all power and the car shuts off. I havent been able to duplicate the problem. Any thoughts?
Old Jan 8, 2004 | 05:19 PM
sb69coupe's Avatar
sb69coupe
Default Re: what would cause total power lose while driving? (bhmyers)
Bad connection at the fuse panel junction on the firewall.
Old Jan 8, 2004 | 05:20 PM
Captain Morgan's Avatar
Captain Morgan
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
bad ground connection somewhere?
Old Jan 8, 2004 | 05:25 PM
bhmyers's Avatar
bhmyers
When I ask him what he done to regain power...... he said he would take a piece of wire from the hot post on the alt and spark it against something and it would come back. I had no clue on that one.
comp's Avatar
comp
Default Re: what would cause total power lose while driving? (Captain Morgan)
bad ign. switch on one car, i just would shut off, but would re-start :banghead:
Old Jan 8, 2004 | 05:34 PM
bhmyers's Avatar
bhmyers
so a bad ingition would cause this? wait a minute his fuel pump is electric and direct wired with a toogle switch, he indicated that that cut off as well which has nothing to do with the ignition.
Old Jan 8, 2004 | 05:50 PM
gkull's Avatar
gkull
I don't know if ths applies to your case. I'm using an aftermarket mallory Unilite ignition which requires a ballast resistor and coil.
When the dist modual failed once in 14 years or so when it got really hot it would just quit. no spark to any plug. Then let it cool off for 15 minutes and it would run fine.
Old Jan 8, 2004 | 06:53 PM
sb69coupe's Avatar
sb69coupe
If he is truly losing ALL power, including non-switched items such as interior courtesy lights, brake lights, etc then it could be a few things. First, as I mentioned, is the junction of the fuse block at the firewall. The hot wire to the ignition there is too small a gauge and the connection tends to go bad over time. Second would be an intermittent open connection on one of the hot wires at the horn relay. Check the fusible links and all the red wires running to the horn relay. Not sure if the '75 has the relay mounted on the drivers side inner fender like the '69.
Old Jan 8, 2004 | 09:38 PM
PRNDL's Avatar
PRNDL
Default Re: what would cause total power lose while driving? (sb69coupe)
generic = bad ground. specific = I had a corroded connection at the negative terminal to my battery. I looked OK, but it was actually loose and corroded and falling apart. When I applied the brakes, battery would shift forward and disconnect. Once the car was at rest, it might restart. When I removed the battery to recharge it the porblem became obvious when the connector/terminal fell apart in my hands. :eek: MJ
A semi-loose connection (at the battery or at the fuse box or elsewher) can become disconnected when you hit a bump or make a turn, shutting down the engine, and loosing all power as you described.
[Modified by MNJack, 9:40 PM 1/8/2004]
Old Jan 9, 2004 | 02:03 AM
LT1driver's Avatar
LT1driver
Default Re: what would cause total power lose while driving? (comp)
I had that happen on a 67, turned out to be a bare spot on wire from dist to coil, bump and shorted and engine quit, check there or other wiring shorts. :cheers:
Old Jan 9, 2004 | 02:51 AM
corvtt1969's Avatar
corvtt1969
Default Re: what would cause total power lose while driving? (LT1driver)
my 69 when i got it had a bad connection at the fuse panel infront of the drivers seat(but inside the engine compartment) i took it apart and put it back together again and never happened again! kinda sucked, driving then the car COMPLETELY shutting down lights, everything. - Bob
To what would cause total power lose while driving?
