Tach problem -'68
Old Jan 10, 2004 | 03:09 PM
BFry's Avatar
BFry
Default Tach problem -'68
I'm getting a loud screeching noise from behind my instrumet panel and my tach went haywire. I believe the cable is toast. How difficult are they to change?
:cool:
Old Jan 10, 2004 | 05:02 PM
JOliver's Avatar
JOliver
Default Re: Tach problem -'68 (BFry)
I'm betting its in the tach main frame instead of the cable...could be both though.More than likely its Tach rebuild time.
Jason
VetteInstruments@aol.com
Old Jan 10, 2004 | 09:51 PM
BFry's Avatar
BFry
Default Re: Tach problem -'68 (JOliver)
Thanks. I guess I know what I'm doing on Sunday
Old Jan 11, 2004 | 03:04 PM
mforman42's Avatar
mforman42
:iagree:
However, while you've got it apart, check the cable. It is cheap insurance to lube and/or replace the cable at the same time. Also, some 68s eat cable drive gears for lunch (the tach drive in the distributer). My 68 427 used to chew up a gear about every year. However, it is very unlikely that you have this problem causing the noise.
Old Jan 11, 2004 | 09:38 PM
BFry's Avatar
BFry
Default Re: Tach problem -'68 (mforman42)
Thanks. I have a cable ordered. Like you said, cheap insurance.
To Tach problem -'68
