OE Stopping Distance?
Jan 10, 2004 | 06:12 PM
Anyone recall what the OE 60-0 stopping distance was for an early C3?
Jan 10, 2004 | 09:37 PM
Re: OE Stopping Distance? (flynhi)
TTT
I wanna know too!
I know for sure they are capable of locking up most any tire...
Jan 10, 2004 | 11:13 PM
Re: OE Stopping Distance? (ZD75blue)
Car and driver june 1972, 60-0 stopping distances:
Base 350: 137 ft
LT-1: 116 ft
454: 122 ft
Don't know why the base engine and LT-1 had such different stopping distances?
Jan 11, 2004 | 12:48 AM
Re: OE Stopping Distance? (zwede)
less weight in the front end maybe? More weight would be harder to stop? Probably relating to the bias of the brakes being offset by weight?
Jan 11, 2004 | 01:05 AM
Will, Here are a couple from the CorvetteArchive,
http://www.corvettearchive.com.
60-0, 145.6 ft, Motor Trend May '70
60-0, 140.0 ft, Sports Car Graphic, June '70
tom...
Jan 11, 2004 | 09:38 AM
Re: OE Stopping Distance? (Tom73)
Were those numbers for auto or 4-speed cars? Did the (4-speed) driver use the engine to assist in braking?
As an aside, even if nothing else were changed, I would think that modern tires would help immensely in this regard.
Jan 11, 2004 | 09:56 AM
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Re: OE Stopping Distance? (Kevin Mason)
Wonder why the big difference between th 70 and 72 numbers. Were the body weights that much different?
Jan 11, 2004 | 10:14 AM
Road&Track Magazine (80mph-0):
1970 454/390 310ft
1973 LT-1 314
1976 L-82 262
1977 L-82 265
1979 L-82 244
1980 L-48 268
1982 ...... 268
Jan 11, 2004 | 10:23 AM
Base 350: 137 ft
LT-1: 116 ft
454: 122 ft
Sure you do. Writers driving! Multiple tests are needed for some sort of accuracy.
http://www.corvettearchive.com/
Jan 11, 2004 | 10:49 AM
Re: OE Stopping Distance? (Ganey)
True. Before ABS driver technique made a big difference. I saw an old road test on TV from the early 70's where their braking test consisted of locking up all 4 wheels! Hardly the shortest braking distance.
Jan 11, 2004 | 02:46 PM
Zwede, Tom, Paul,
Thanks for the info. Did any of the test indicate whether the test cars were equipped with the HD brake option (J56?)?
[Modified by flynhi, 1:47 PM 1/11/2004]
Jan 11, 2004 | 02:52 PM
Re: OE Stopping Distance? (paul67)
1970 454/390 310ft
1973 LT-1 314
1976 L-82 262
1977 L-82 265
1979 L-82 244
1980 L-48 268
1982 ...... 268
Thanks Paul for the information, quite interesting to see that the heavier 79 had shorter stopping distance versus the lighter 80!? :cheers:
Jan 11, 2004 | 02:58 PM
I believe J56 was 1968 and 1969 only. So that was not a factor in the results I posted.
Jan 11, 2004 | 03:01 PM
Re: OE Stopping Distance? (groovyjay)
You really have to take the stats with a grain of salt. It really depends on the driver and how many journalists from X magazines abused the car that day. The variables are many and difficult to control.
Jan 11, 2004 | 05:17 PM
It could be that the 79 had the optional tires.
These numbers are almost entirely based on tires and driver skill. I doubt any of us would get these numbers today. Btw, has anyone checked their own car with a gtech or something?
1970 ,
1973 ,
1977 ,
1979 ,
1994 ,
2000 ,
2002 ,
brake ,
braking ,
c3 ,
chevrolet ,
corvette ,
distance ,
stoping ,
stopping
