door access panels
Old Jan 11, 2004 | 09:07 AM
jetech's Avatar
jetech
Default door access panels
Does anyone have a picture of the window motor access panels for a 77. Mine are missing and I need to make a set.
:smash: :seeya
Old Jan 11, 2004 | 10:31 AM
mapman's Avatar
mapman
Default Re: door access panels (jetech)
Does anyone have a picture of the window motor access panels for a 77. Mine are missing and I need to make a set. ....
Sorry, I don't have a picture. They are just "dished out" somewhat for clearance. I would purchase a set from a Corvette junkyard before I took the time to make some.
If the access panels are missing, it may be that the water barrier plastic is missing also. (Plastic sheet that covers the metal part of the door. Secured with adhesive around the perimeter of the door.) Just a thought.
1968-1977 were the same, the part numbers are left side 3922279, and 3922280 for the right side. 1978-1982 have a different part number, I don't know if they can be made to work.
There is a gasket around the access door as well.
[Modified by mapman, 9:39 AM 1/11/2004]
Old Jan 11, 2004 | 07:10 PM
Duke94's Avatar
Duke94
I have the door panel off my 78' and can take pictures, will that do you any good? To be honest, they don't look much different than the ones on my 71'
Old Jan 11, 2004 | 11:00 PM
jetech's Avatar
jetech
Default Re: door access panels (Duke94)
Duke94
That should work. Thanks :cheers: :cheers:
Old Jan 11, 2004 | 11:07 PM
DMONSVETTE's Avatar
DMONSVETTE
Saw a bunch of them for sale on ebay on Thursday. :yesnod:
To door access panels
