Need help with vortec heads.
Old Jan 11, 2004 | 12:00 PM
Ebbsvette's Avatar
Ebbsvette
Default Need help with vortec heads.
I need to know how much to grind the bosses down. I need it to handle a .500 lift cam. Thanks
Old Jan 11, 2004 | 10:12 PM
American Boy's Avatar
American Boy
Default Re: Need help with vortec heads. (Ebbsvette)
I run 0.502'' valve lift exh and 0.495'' valve lift int without any modification. I did change the spring to accomodate the higher lift and I mesured the coil bind height to be sure everything would be clear. They can handle 0.550'' lift and have the stock diameter. You can find them at Scoggin-Dickey : http://www.sdpc2000.com/cart.asp?act...060&pid=154158
Good luck
Stephan
[Modified by American Boy, 10:14 PM 1/11/2004]
