fan clutch
Old Jan 13, 2004 | 02:16 PM
trackdogg's Avatar
trackdogg
Default fan clutch
does any body know where I can get a fan clutch that doesn't cost a 150.00 dollars on a 73. Went through flex-a-light and it didnt bolt up right. Housing to water pump to small in circumference. any one running a 16"electric by itself and not having overheating problams.
Old Jan 13, 2004 | 02:34 PM
Stewart's74's Avatar
Stewart's74
Default Re: fan clutch (trackdogg)
Try contacting Gary Gruhala.
Old Jan 13, 2004 | 02:49 PM
gerry72's Avatar
gerry72
Or having your factory original overhauled and restored: http://www.gate.net/~foliva/
Don't click if you're looking for cheap.
Old Jan 13, 2004 | 02:57 PM
Fevre's Avatar
Fevre
This is what you need to run the flex fan:
http://store.summitracing.com/partde...rt=SUM%2DG4955
Old Jan 13, 2004 | 05:16 PM
JB's Avatar
JB
St. Jude Contributor
Or just go to Autozone. I just bought a clutch to use temporarily on my '69 big block for $35 (BTW, I'm looking for an original if somebody's got one they want to sell! :D).
JB
Old Jan 13, 2004 | 09:14 PM
trackdogg's Avatar
trackdogg
Default Re: fan clutch (JB)
was the hub on the clutch the same size as the one on the water pump.
Old Jan 13, 2004 | 09:49 PM
JB's Avatar
JB
Yes and no. The mounting flange/hub has slots rather than holes, so it's a "universal" fit for the bolt pattern. The center "pilot" hole in the flange has a removable brass bushing so that it can fit both 3/4" and 5/8" water pump shafts. Bottom line, it fits and operates just fine with my OEM fan.
JB
Old Jan 13, 2004 | 10:08 PM
no_radio's Avatar
no_radio
I am swapping in an electric setup for my '74. I have an AC Delco '74 with AC fan clutch that I bought brand new 3 years ago, about 2000 miles, no problems. If you are interested email me, maybe we can work a deal. This thing is clean as a whistle, I've been showing the car mostly until this year.
The AutoZone price on a '74 fan clutch is about $80, I just checked today cuz I was going to try to sell this to JB, but this one won't fit his car.
Jeff
To fan clutch
