Do Carb Heat Shields Work?
Old Jan 18, 2004 | 11:42 AM
redvetracr's Avatar
redvetracr
Default Re: Do Carb Heat Shields Work? (paul67)
paul,
The GM part is about 1/2 that price and I believe STILL AVAILABLE!!
...redvetracr
Old Jan 18, 2004 | 12:14 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
Default the GM part numbers are
for holley,#3969835 and for a q jet # 3969837 i do not think they are still available,check with a dealer :chevy
paul,
...redvetracr
Old Jan 18, 2004 | 12:25 PM
Barry's70LT1's Avatar
Barry's70LT1
Hi Paul,
I used the GM heat sheild for over 20 years. It worked well.
However, since 1996 I've used the composite spacer and it works as well.
I find the composite spacer does not interfere with hoses etc like the sheild does.
Either one should do the job.
Barry
Old Jan 18, 2004 | 12:51 PM
Paul L's Avatar
Paul L
Default Re: Do Carb Heat Shields Work? (redvetracr)
Oops! I have the Holley version on order from the speedshop. I will go through with the transaction.
Old Jan 18, 2004 | 12:52 PM
Paul L's Avatar
Paul L
Default Re: Do Carb Heat Shields Work? (Barry's70LT1)
Thanks Barry. I do have concerns re interference. We shall see. I see you're still living in God's Country!
Old Jan 18, 2004 | 01:15 PM
redvetracr's Avatar
redvetracr
Default Re: the GM part numbers are (clem zahrobsky)
SORRY Clem is correct (sort of) they are available through the parts locater service. ...redvetracr
Old Jan 19, 2004 | 12:27 PM
Matt Gruber's Avatar
Matt Gruber
could also pop the hood open, a PITA, but it works 100% :cool: gas boils ~140o!
Old Jan 19, 2004 | 01:55 PM
Paul L's Avatar
Paul L
Here is the Holley heatshield I purchased today mocked up on a 1967 intake. There was a tab at the back that did not clear the vacuum fitting so I did a Bubba...neatly folded it under. The cut-out for the choke linkage looks fine. There may be a wee bit of interference in the front with the thermostat housing; it is bulbous. And there might be a problem with the crankcase vent tube coming up from the back of the engine to the underneath of the air cleaner. So its a bit of a crapshoot until I see my car in April. But it came with a 3/8" spacer and that in itself is a fallback option.
[Modified by paul67, 7:16 PM 1/19/2004]
