Do Carb Heat Shields Work?
Old Jan 17, 2004 | 08:37 AM
Paul L's Avatar
Paul L
Default Do Carb Heat Shields Work?
To prevent fuel bowl boiling?
http://www.jegs.com/cgi-bin/ncommerc...20&prmenbr=361
Old Jan 17, 2004 | 08:50 AM
mrvette's Avatar
mrvette
Default Re: Do Carb Heat Shields Work? (paul67)
NO, not for a street driven car....IMO the only thing to do is pull the manifold and clean it up, and pour plaster of paris down the heat crossover passageway, thereby blocking it completely, and same with the EGR if you want, at least get rid of the EGR at any rate...blocking all passages....
nice if you can somehow keep engine oil off the bottom of the manifold....
Pontiac and BB Mopar used to do their manifolds in a spyder web design and use a valley pan for that reason....someone tooled up and did the same concept for SBC also....
but there is no other cure....might want to run engine at lower temp if you cooling system is up to the task....
GENE
Old Jan 17, 2004 | 09:44 AM
Paul L's Avatar
Paul L
Default Re: Do Carb Heat Shields Work? (mrvette)
I hesitate to go in that direction as temperatures during the driving season here (April to October) can vary from 25-100F and I prefer to retain the crossover for quick warmup at the lower temps. And to block the crossover would mean that the heat riser would have to be removed as well: when it is closed at start-up where would the passenger side exhaust go? So the heat shield seemed to offer cheap insurance against fuel boil.
The intake in the pic is the same as the unit (GM #3890490) on the car. It does have the crossover passage but no EGR. And an oil splash shield is installed.
Old Jan 17, 2004 | 11:49 AM
Double Aught's Avatar
Double Aught
I used one a 64 GTO and it helped. Those 389's in a small engine compartment, well, you know how that goes. You're right, it's cheap insurance.
Old Jan 17, 2004 | 01:03 PM
Robert N's Avatar
Robert N
Default Re: Do Carb Heat Shields Work? (Double Aught)
Paul,
I clipped this from a post Lars wrote in another thread:
Finally, the BG is very sensitive to manifold heat: The heat coming off the manifold will easily boil the fuel in the big accelerator pump housing, causing the carb to flood out after shutdown. To prevent this, yu need to use one of the Holley reflective heat shields between the carb and the manifold - a carb spacer will NOT solve the problem - you need the reflective shield.
While I have little experience in this area, common sense would tell me (as would Lars I think) that the benefit of a heat shield will be dependent on several circumstances including the carband intake used. I can easily see some carbs being more susceptible to the "boil over" issue based on their design (size and location of components, material used - aluminum manifolds dissapte heat faster than iron and should prevent less issues).
Would I just throw one on, yes if the cost was minimal; if the cost was great or originality a concern, not without testing my set uip through a little trial and error.
Old Jan 17, 2004 | 01:32 PM
Paul L's Avatar
Paul L
Default Re: Do Carb Heat Shields Work? (Robert N)
Thanks Robert. I do not know what a BG but here is my setup. The carb is the stock Holley 4160. I dropped by a local speedshop today to see if the Holley shield is available in Canada. It is and I will have one on Monday. I can't see that it will do any harm. And the price is reasonable as I do not have to pay shipping, brokerage fees, etc. There may be a fitment issue with that rear vacuum fitting. If yes, I will improvise.
Old Jan 17, 2004 | 01:36 PM
Robert N's Avatar
Robert N
BG = Barry Grant.
I have a 650 DP Holley on thge stock high rise aluminum intake with no issues and no heat shield. Summer temps here are like your winter lows - 110+ is not uncommon with a avergae at 100+ degrees.
I agree that for the price, the shield cannot hurt and I will probably add one as well when the time comes.
Old Jan 17, 2004 | 01:50 PM
pillowmeto's Avatar
pillowmeto
i would think oneof those 1/4 inch thick heat disapating spacers woudl do alot more
its a thin layer of aluminium then a layer of a composite or somehting that doesnt transmit heat well and then another layer of aluminium
or a thin wood spacer also some composite thin spacers and other types of heat disapating gaskets. They just limit the heat transfered to the carb by the intake manifold.
MAtt
Old Jan 17, 2004 | 02:05 PM
Paul L's Avatar
Paul L
Default Re: Do Carb Heat Shields Work? (pillowmeto)
The Holley kit does come with a 3/8" spacer. Perhaps it will provide the heat insulation properties you are mentioning.
Old Jan 17, 2004 | 02:08 PM
Paul L's Avatar
Paul L
The price is about $30US so worth a try at that cost.
Old Jan 17, 2004 | 02:10 PM
JJMURFS's Avatar
JJMURFS
Paul
I've used the original GM heat sheild that looks very much like the one you posted a link to. I've had the same setup on 3 cars (2 BB & 1 SB) now all with aluminum manifolds and dual feed Holley carbs. and have had no boiling problems at all.
Old Jan 17, 2004 | 02:53 PM
mrvette's Avatar
mrvette
Sorry Paul, didn't notice Canada there on your addy.....
in that climate, I would take off any heat risers, and just run open passages under the carb....and call it quits....
GENE
Old Jan 17, 2004 | 03:17 PM
Paul L's Avatar
Paul L
Thanks Gene. That is an option as well. Those heat risers do tend to freeze up with time. I think muffler shops have the replacement spacers.
Old Jan 17, 2004 | 04:01 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
chevy used them on some engines so i would guess they work. they do not spend a $.01 they do not have to. it keeps the heat from the float bowls when the engine is shut off.
[Modified by clem zahrobsky, 4:02 PM 1/17/2004]
Old Jan 17, 2004 | 04:02 PM
Brettmc's Avatar
Brettmc
I have the same Holley heat shield and it didn't help my randomly-occurring problem of fuel spitting out the air bleeds after the car is turned off.
Brett :thumbs:
Old Jan 17, 2004 | 04:22 PM
Gordonm's Avatar
Gordonm
Default Re: Do Carb Heat Shields Work? (Brettmc)
I have the same problem of teh fuel spitting out of the air bleeds. I have no heat crossover in my heads. It is just the heat from the manifold tha tboils the fuel when it is shut off. I would like to find a cure for this. Every time I go to start it after sitting for 15 minutes it is flooded due to the fuel in the intake. It is a pain to start.
Old Jan 17, 2004 | 04:42 PM
Paul L's Avatar
Paul L
Default Re: Do Carb Heat Shields Work? (Gordonm)
That is the problem I experienced last summer.
To Do Carb Heat Shields Work?
Old Jan 17, 2004 | 09:15 PM
rponfick's Avatar
rponfick
paul67, I also see from your carb photo that your Holley has a divorced choke, which will also not work if you plug the heat crossover passages. Why is it that one thing always leads to another.
Old Jan 18, 2004 | 08:08 AM
Paul L's Avatar
Paul L
Default Re: Do Carb Heat Shields Work? (rponfick)
I did not realize that. I am going to try the shield and hope for the best.
Old Jan 18, 2004 | 11:17 AM
jimtreber's Avatar
jimtreber
I used the actual Chevy heat shield plus insulator spacers on a Victor JR and still had heat problems. My solution was to go with a Carter Competition Series 750 and never had another problem.
1976 406 TH400 3000stall 4.11 gears
[Modified by jimtreber, 4:25 PM 1/18/2004]
