First timer on the dragstrip
Old Jan 21, 2004 | 09:59 PM
Rockn-Roll's Avatar
Rockn-Roll
Default Re: First timer on the dragstrip (ATHANASE)
I'd say Solid LT1 has some solid advice...no pun intended...unless you wanted one there.
You definitely need to get that clutch fixed. I recommend the Centerforce Dual Friction, it's what I installed before heading to the track and I was able to hold 3,000 RPM then release the clutch and got NO slippage. My tires were the BFGoodrich Comp T/A R1's and they stuck like glue. But, although you can still get a Centerforce Dual Friction clutch BFGoodrich no longer makes the R1's. Instead I recommend the Dunlop SP Sport 8000's which come in a 245/ZR50-15. This tire has a treadwidth just as large as the current BFGoodrich Radial T/A 275/SR50-15's, but a tighter sidewall for better cornering. The Dunlops will keep your car on the move on or off the track.
But, of course...most important part is HAVE FUN!!! :party:
Old Jan 29, 2004 | 10:38 PM
ATHANASE's Avatar
ATHANASE
Default Re: to all
Thank you all for your feed back.
I appreciate Rockn-Roll's advice: I make sure I have fun.
Thanks again, Folks.
