Smart Struts or regular adjustable struts
Old Jan 19, 2004 | 07:52 AM
7t5's Avatar
7t5
St. Jude Donor '14
Default Smart Struts or regular adjustable struts
Should I pay the extra dough for smart struts for a daily driver? A spring and some strut rods willbe my first rear mods. I have just about settled on a steel spring due to all of the negative posts on composite types.Thanks! :confused:
Old Jan 19, 2004 | 08:18 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: Smart Struts or regular adjustable struts (7t5)
I have had my camber cams move more than once. I have been thinking of going to smart struts myself. I will be following this post closely.
Old Jan 19, 2004 | 08:37 AM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: Smart Struts or regular adjustable struts (Eddie 70)
Adjustable struts rock...
Old Jan 19, 2004 | 08:38 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Well w/smart struts you lower the center point of the strut rod and what this does is, it reduces the side load on the bearing assemblies. It will also reduce the wear on the bearing assemblies b/c it's taking some side load off. Smart struts will give you a more even tire wear and improve handling. With them your camber change is less than 1 tenth of a degree over 5-1/2" of wheel travel as opposed to 2 degrees at 2 /12" of wheel travel. Bottom line is it worth it, Yes.
Old Jan 19, 2004 | 09:37 AM
NHvette's Avatar
NHvette
I've had my lock nuts on the adjustable struts come loose more than once.
You really gotta tighten them down ... locktite ... or a little rust to keep 'em in place.
I'm a little put off to pay more for (essentially) an offset bracket.
Plus, some will argue that zero camber change is not as good as it sounds, as
some negative camber can help the tire grab around corners.
:seeya
Old Jan 19, 2004 | 10:44 AM
68raggtop's Avatar
68raggtop
Default Re: Smart Struts or regular adjustable struts (NHvette)
Any one try the HD adjustable struts that don't have a rubber bushing?
Old Jan 19, 2004 | 12:37 PM
markdtn's Avatar
markdtn
Default Re: Smart Struts or regular adjustable struts (68raggtop)
I have the regular adjustable and they are great. :)
Old Jan 19, 2004 | 12:41 PM
427V8's Avatar
427V8
I run the solid heim jointed strut rods. see my post above for my opinion...
Old Jan 19, 2004 | 05:10 PM
Van Steel's Avatar
Van Steel
Default Re: Smart Struts or regular adjustable struts (427V8)
427V8
I thought you were and I was going to say that you did but I wasn't 100% sure. Glad to hear you like them though
To Smart Struts or regular adjustable struts
