Need work done on differential....
Old Jan 19, 2004 | 04:07 PM
Chumpzilla's Avatar
Chumpzilla
Default Need work done on differential....
..... anyone know of someone/place in the Dallas area that you'd recommend. Got a worn axle stub with a ring that's disintegrated.... lots of axle play in/out.... also need to get it checked out to make sure nothing else needs repair. Any recommendations are appreciated. Thanks.
Old Jan 19, 2004 | 04:57 PM
74 vert's Avatar
74 vert
From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
Default Re: Need work done on differential.... (Chumpzilla)
Good luck. I'm in the same boat, needing differential service. I found a local 4x4 shop that will rebuild mine for $150 plus parts.
Old Jan 19, 2004 | 05:00 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Default Re: Need work done on differential.... (74 vert)
74 Vert
Thats not a bad price.
Old Jan 19, 2004 | 05:15 PM
comp's Avatar
comp
Default Re: Need work done on differential.... (Van Steel)
iron center????
Old Jan 19, 2004 | 05:55 PM
GTR1999's Avatar
GTR1999
That is a good price I would ask him some more questions. I was rebuilding a 72 differential today in fact. I'm using a new set of Tom's 3:08s, new Eaton solid clutches, rebuilt kit, rebuilt yokes,misc things and the parts cost is $520.
What are you getting for $150, just labor?If so then not a bad deal. Usually just a rebuild kit,clutches,and labor run $500-$600 depending who does the work.
Gary
[Modified by gtr1999, 5:57 PM 1/19/2004]
Old Jan 19, 2004 | 10:06 PM
kenko74's Avatar
kenko74
Send it to Vansteel! They won't rip you off--only quality work at a fair price.
Old Jan 19, 2004 | 10:18 PM
SharkAttack's Avatar
SharkAttack
Have you tried "Corvettes of Dallas"?
Old Jan 19, 2004 | 11:53 PM
74 vert's Avatar
74 vert
Default Re: Need work done on differential.... (SharkAttack)
Chumzilla, I don't think you can go wrong with VanSteel. I purchased my rear spring, front sway bar and Bilsteins from them and they took care off me. I'm contacting them for my differential parts as well.
I'm considering the local 4x4 shop for rebuild since they are local, rebuild a lot of diffs for both 4x4, race and local car enthusiast. Further, I'm hoping to watch some or most of the work, so I can learn how a differential comes apart and goes back together. I like the idea of dropping my differential, throwing it in the back of my pick-up and running it down to the shop.
Comp, iron center?? I don't know anything about differentials what's an iron center, etc?
[Modified by 74 vert, 10:55 PM 1/19/2004]
To Need work done on differential....
