ASTRO Ventilation?
Old Jan 19, 2004 | 04:31 PM
wacked's Avatar
wacked
From: If the world didnt suck, we would all fall off. Troy,Ohio.
Cruise-In VI Veteran
St. Jude Donor '04-'05-'06-'07-'08
Default ASTRO Ventilation?
My drivers side window says that at the bottom, what is it??
Old Jan 19, 2004 | 04:34 PM
James's Avatar
James
Default Re: ASTRO Ventilation? (wackedvette)
Poor mans air conditioning.
This was something that GM did on Camaros and Corvettes.
Its bascially a way to get fresh air into the cockpit through vents.
Old Jan 19, 2004 | 07:11 PM
guppie's Avatar
guppie
St. Jude Donor '08
My "68" Z28 had that also
Old Jan 19, 2004 | 10:14 PM
RHD '68 L89's Avatar
RHD '68 L89
Flow through ventilation. The previous models did not have a "flow through" system for fresh air. If you wanted fresh air from the heater/vent you had to run the fan or open a window.
With astro ventilation there is a vent at the rear of the cabin which allows air to exit the cabin through the vents in the rear deck.
:cheers:
Old Jan 19, 2004 | 10:17 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VII Veteran
The flow through ventilation was only hooked up on non-A/C cars. If there wasn't an A/C then there were a couple of vacuum actuators in the back of the car that opened up and flowed air out through the grills on the back deck.
Old Jan 19, 2004 | 10:44 PM
RMVette's Avatar
RMVette
Default Re: ASTRO Ventilation? (Smokehouse69)
:iagree:
Old Jan 20, 2004 | 02:06 PM
zzyzx's Avatar
zzyzx
What climate controls activate the rear actuators? Is it the "AIR" setting on the heater, or the vent arms on either side of the console?
Old Jan 20, 2004 | 02:18 PM
Z-man's Avatar
Z-man
Default Re: ASTRO Ventilation? (zzyzx)
The side vent arms don't have anything to do with the astro ventillation (AV). The AV vents should be open in the AIR position, and closed in the recirculation postion.
Notice also, there is no "off" setting on the fan. It runs continuously when the car is running, thus providing you with comfortable, mountain-meadow fresh, flow-through ventillation... :D
[Modified by Z-man, 12:18 PM 1/20/2004]
[Modified by Z-man, 12:19 PM 1/20/2004]
Old Jan 20, 2004 | 02:34 PM
wacked's Avatar
wacked
Default Re: ASTRO Ventilation? (Z-man)
Thats true, there is no off for my fan.
Old Jan 20, 2004 | 02:41 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
The only time the Astro Vents close is when you turn the temperature dial up. Otherwise if no heat/temp is dialed in the Astro Vents are open. Only the temp side of the heater control makes the Astro Vent doors open or close.
Old Jan 20, 2004 | 02:43 PM
Stoge's Avatar
Stoge
My best friend's '69 Chevelle has that. Funny, he also said it was "poor man's air conditioning."
:D
Old Jan 20, 2004 | 03:30 PM
CruisinCO's Avatar
CruisinCO
Hey Z-Man-
I'm not sure where Foxfiled is, but here in the Denver area, I dont get a good wiff of the Mt's in my '69 until I'm north on I-25... or West 6th Ave.. :auto:
Old Jan 21, 2004 | 07:56 AM
reidry's Avatar
reidry
Default Re: ASTRO Ventilation? (CruisinCO)
I'm looking at completely removing the heater and possibly the fan in my '69, has anyone done a manual control of some type for the rear deck vents? Also if the fan is off does the system have any flow at normal driving speeds?
Ryan
Old Jan 22, 2004 | 02:22 PM
Z-man's Avatar
Z-man
Hey Z-Man-
I was trying to envision what the Corvette ads would have been saying in the late '60s and early '70s. :)
Old Jan 22, 2004 | 03:23 PM
68shark's Avatar
68shark
This is a good post! I had no idea how this system operated! Wonder if mine actually works or is it like my clock....long dead! :lol:
Old Jan 22, 2004 | 04:44 PM
RHD '68 L89
On '68's there is no actuator on non A/C cars. Just a flap which opens under positive pressure in the cabin.
Unsure of A/C cars in '68.
I believe the actuator was introduced in '69.(for non A/C cars anyway)
Another '68 only thing!
:cheers:
Old Jan 22, 2004 | 04:47 PM
wacked's Avatar
wacked
Default Re: ASTRO Ventilation? (RHD '68 L89)
Mine has 2 levers on the heater control. From there theres a cable running to the side vents under the dash.
To ASTRO Ventilation?
Old Jan 22, 2004 | 04:59 PM
Shrike's Avatar
Shrike
My '69 (non A/C) has a lever on either side of the console to control the vents.
Old Jan 22, 2004 | 05:02 PM
RHD '68 L89
They are to get the fresh air in.
The astro ventilation is to get the air out of the cabin. If there is nowhere for the air to flow to, a positive pressure builds up in the cabin and no fresh air can flow into the cabin.
:cheers:
Old Jan 22, 2004 | 06:42 PM
jdunne's Avatar
jdunne
James,my astro vent rear deck positively air pressure activated black flap makes an almost infinitesimal difference to my convertible(esp with the roof down).....given all the airleaks i have with the roof up it probably would never work as designed so i have just left it open......john :chevy
[Modified by jdunne, 5:45 PM 1/22/2004]
