Z28 Rims
Old Jan 19, 2004 | 06:34 PM
PewterMetallic98's Avatar
PewterMetallic98
Default Z28 Rims
Would stock Z28 rims off a newer model Z28 bolt up to the 81 corvette bolt pattern? Has anyone ever accomplished this before? I have a sweet deal on some but im not too sure how they will look or fit. Thanks for the help. :cheers:
Old Jan 19, 2004 | 06:43 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Default Re: Z28 Rims (ElectronBlueC3)
the bolt pattern sould not be an issiue I would be more concerd with the off set of the wheel :confused:
Old Jan 19, 2004 | 08:54 PM
stpman's Avatar
stpman
Default Re: Z28 Rims (Nowhere Man)
What year Z28 wheels are you thinking of?
The wheels that came off my 87 IROC with 4 wheel discs
had different back spacing front to rear. the wheels even had "FRONT & REAR" cast right in the wheels.
Steve :steering:
Old Jan 19, 2004 | 09:05 PM
PewterMetallic98
Default Re: Z28 Rims (stpman)
They are a set of 2000 Z28 rims. Any idea about them??
Old Jan 19, 2004 | 10:36 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Offset will get you, but you might be able to get spacer adapters and bolt them up.
Old Jan 19, 2004 | 10:38 PM
PewterMetallic98
Default Re: Z28 Rims (Smokehouse69)
Ok, I'll have to look into that. Thanks again for the replies guys. :yesnod:
Old Jan 19, 2004 | 10:57 PM
stpman's Avatar
stpman
Not sure about the offset but I found this that might help
http://www.custom-spinning-car-truck.../Chevrolet.htm
Steve :steering:
Old Jan 19, 2004 | 11:01 PM
wacked's Avatar
wacked
From: If the world didnt suck, we would all fall off. Troy,Ohio.
St. Jude Donor '04-'05-'06-'07-'08
Thay will fit till 84, I have a front set of 84Z rims. You can have them.
There 15".
Old Jan 20, 2004 | 03:27 PM
markdtn's Avatar
markdtn
Default Re: Z28 Rims (wackedvette)
I have 88 16" IROC wheels on my 69. You have to use 4 fronts due to the offset.
To Z28 Rims
