Replacing body mount cushions HELP!!!
Old Jan 21, 2004 | 02:03 PM
madman's Avatar
madman
Default Replacing body mount cushions HELP!!!
In my '79 rebuild I'm replacing the body mounting cushions as a preventative measure, but it looks like this may be more difficult than I thought. All running gear is out of the car. Any suggestions on how to make this easier? Pulled out 6 cushions bolts. Two had severe rust and the metal in one cushion fell out as dust! So now I'm committed.
Old Jan 21, 2004 | 02:19 PM
NHvette's Avatar
NHvette
Default Re: Replacing body mount cushions HELP!!! (madman)
Hey - you got 6 out - without cutting or burning them out - pretty good.
The #1,#2,and #3 bolts on my 70 came out with a ratchet. The #4 was frozen
to the nut - which simply spun around in the nutcage inside the body.
I cut the heads off with an angle grinder to get those off.
So, where do you need help.
mentally, right ?
:lolg:
Old Jan 21, 2004 | 02:32 PM
Chumpzilla's Avatar
Chumpzilla
madman...
Check your email... I'm in the Dallas area and also doing a '79 resto. Might be able to help each other out.
I've got a '79 L82 4 speed.... just beginning my restoration.
Old Jan 21, 2004 | 02:55 PM
VBP's Avatar
VBP
St. Jude Donor '07,'13
Default Re: Replacing body mount cushions HELP!!! (Chumpzilla)
VBP is starting our 79 project car next week. New crate motor, interior, brakes, suspension, steering, wheels, body work, paint and so on...............
I am pricing all components out right now to see if I am going to come in at or under budget ( yeah right ! ). We will have weekly updates on our webpage about this starting pretty soon, script and photos. The body is getting pulled starting this weekend and then one weekend off for the Super Bowl and then back to the grind. Hope all your projects go well ! Good luck !
Tony
VBP
Old Jan 21, 2004 | 02:57 PM
Chumpzilla's Avatar
Chumpzilla
Default Re: Replacing body mount cushions HELP!!! (VBP)
Thanks for the info.... I'll keep an eye out... might learn a thing or two!
Old Jan 21, 2004 | 06:00 PM
redwingvette's Avatar
redwingvette
Might want to checkout my body-off on home page for a list of things to do the job. A lot of good help is available on this forum. Good luck
Old Jan 21, 2004 | 09:16 PM
Tom77's Avatar
Tom77
Red Wing and Smokehouse helped me in the right direction on this job. I don't know where you need help but the rear bumper will have to be disconnected at the frame. Four bolts on each side at the energy absorbing assembly have to come out. Steering rag joint has to be split. Front bumper on the 79 i'm not sure. You might have to disconnect something. Ground wire in front of #1 mount driver side has to be disconnected. Body will have to be jacked up about 2-3" to get the mounts in. I have my driver side done now. I'm a slow worker. Any other info I can provide E-mail me. Tom
Old Jan 23, 2004 | 12:05 AM
madman's Avatar
madman
Default Re: Replacing body mount cushions HELP!!! (Tom77)
Looks like REDWINGVETTE'S web page has a good outline on what I need to do. Just afraid a rebuild to have a nice driver will turn into a frame off restore.
WILL IT NEVER END..... :smash:
Old Jan 23, 2004 | 08:05 AM
redwingvette
Don't let it scare you. I did everything by myself untill it came time to set the body back down (4 eye's are better than 1).
Old Jan 23, 2004 | 07:38 PM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
You can go to your favorite GM parts counter and order 8 #334755 cushions to replace them all
To Replacing body mount cushions HELP!!!
