Stock tie rod lengths
If you're wonderin', I'm planning to replace with Heim ends, spaced to aid bumpsteer.
Thanks!
Chris
Give me till late this afternoon to give you all the particulars on what you want.
Doing the math a new replacement sleeve for using a heim joint on one end and the stock tie rod on the other you get an 11 inch sleeve, # RP-127-11 from coleman racing , cost $9.05.
5/8th heim joint left hand #931-LM Cost $11.85 from Coleman. 2 left hand jam nuts 941-L Cost $.70.
You also need 2 5/8th bolts, 3.5 inches long and 2 locking nuts.
A 1 inch long spacer 1 1/4 inches diameter works as a good spacer.
I would remove the steering arms and they come out with just 2 bolts, Weld the 1 inch spacer to the steering arm and drill the arm and spacer to 5/8 inch with a prentise drill.
This removes most of the bump steer on out vets or at least reduces it to alot less then a new mustang.
This is the welded on spacer and I also cut the end of the steering arm off and ground it to round everything off.
Double click to enlarge
[Modified by norvalwilhelm, 3:15 PM 1/24/2004]
Post of it before changing anything and I can list the steps if you go this route.
With this setup alone I ended up with bump up maximum of 5/16th and bump down of .015. This none straight line showed the tie rod sleeves were not right but it was alot better then before.
As for now, I have a speeding ticket, new tires, and an alignment to pay for, here's my tires when I got back from NC (by way of Bowling Green and the NCM):
