Sway Bar Install
Old Jan 22, 2004 | 06:54 PM
flynhi's Avatar
flynhi
Default Sway Bar Install
I spoke with Robin at VBP this afternoon about ride quality in my 71. He thinks my problem may be binding sway bars.
According to VBP, sway bars should be installed loose - with the ends disconnected, they should freely rotate in the bushings. If they bind, add grease and washers until all resistance is removed.
I'm on it tonight..........
Old Jan 22, 2004 | 07:06 PM
74 vert's Avatar
74 vert
From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
Default Re: Sway Bar Install (flynhi)
Binding, how does the car perform if it's binding?
Old Jan 22, 2004 | 11:01 PM
flynhi's Avatar
flynhi
Default Re: Sway Bar Install (74 vert)
According to Robin, the suspension will bounce as the sway bar binds and then releases.
Old Jan 23, 2004 | 01:16 AM
LiveandLetDrive's Avatar
LiveandLetDrive
I didn't think about needing to shim down the bushing-bracket, but I did lithium-grease inside the bushings. The before and after difference was huge. (tested by hand, hadn't driven enough without grease for a comparison) You may want to look at the control-arm links for binding also.
[Modified by RUXperienced, 12:17 AM 1/23/2004]
To Sway Bar Install
