brake bleeding....question
Old Jan 22, 2004 | 10:08 PM
corvtt1969's Avatar
corvtt1969
Default brake bleeding....question
do you need to bleed all the calipers if you only work on one? i accidentally pulled apart one and it leaked a little i bled it and it seems to be ok but i havent taken it out yet cause i dunno if i should bleed all of them? thanks-Bob
Old Jan 22, 2004 | 10:31 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: brake bleeding....question (corvtt1969)
As long as the line to that caliper stayed full of fluid, you don't need to bleed the other calipers.
Old Jan 23, 2004 | 12:34 AM
Z-man's Avatar
Z-man
You will know if you need to bleed any others by the feel of the pedal. Chances are that you won't have to bleed the others.
Good luck... :)
Old Jan 23, 2004 | 02:46 AM
corvtt1969's Avatar
corvtt1969
Default Re: brake bleeding....question (Z-man)
thanks guys! the pedal feels pretty firm pushing down on it in the garage ill drive it up and down the driveway before i take it out on the road just incase! thanks again- Bob
p.s. i finally got rid of that stupid brake light that stays on even when you put the e brake down! its got something to do with the brake system. bout time!
To brake bleeding....question
