Spark Plug Torque
Jan 24, 2004 | 02:11 PM
Spark Plug Torque
Can anyone tell me what this should be?
Jan 25, 2004 | 08:22 AM
Re: Spark Plug Torque (Bobchad)
I'm not sure if the torque varies from one engine type to another, but for what it's worth my '69 service manual specifies 25 ft-lb for the plugs. This is for a 427/390 engine. Hope this helps.
Jan 25, 2004 | 08:36 AM
Consult the plug manufacturers specs, believe most with the crush washers state 1/4 turn past snug, I pretty much use that all the time.
Jan 25, 2004 | 01:06 PM
My 72 service manual states, 14mm, 5/8 15 lb. ft.
Jan 25, 2004 | 02:24 PM
Re: Spark Plug Torque (Fevre)
This procedure has worked great for years! No need to reinvent the wheel.
Jan 25, 2004 | 02:54 PM
:iagree:
Jan 25, 2004 | 04:01 PM
Anybody ever have a spark plug fall out? The risk, and tendency, seems to be to overtighten. MJ
Jan 25, 2004 | 04:06 PM
Re: Spark Plug Torque (MNJack)
Didn't think to check the Service Manual. 15 for tapered plugs.
Jan 25, 2004 | 04:17 PM
St. Jude Donor '03,'11
be carefull if you have aluminum heads. You don't wanna strip it out. Always use anti sieze on aluminum heads.
1968 ,
2002 ,
427 ,
c6 ,
colorado ,
corvette ,
plug ,
settings ,
spark ,
torque ,
type
