Close headlights manually
Old Jan 25, 2004 | 11:12 AM
Jim Strathearn's Avatar
Jim Strathearn
PA Events Coordinator
Cruise-In II Veteran
Default Close headlights manually
Is there a way to safely close the headlights manually?
Thanks...
Old Jan 25, 2004 | 11:44 AM
Gordonm's Avatar
Gordonm
Default Re: Close headlights manually (Jim Strathearn)
Yes there is. The headlamp linkage is kind of a knee action You have to reach up under the front end and find the "knee" in the linkage. If I remember right move it a little towards the rear and the headlamp will come down. You will see the "knee" it should have 4 springs attached to it to aid in the raising and lowering of the headlamps.
BKbroiler's Avatar
BKbroiler
Someone else will reply with more detail - but the answer is yes. I've done it. You have to get under the nose of the car with a flashlight and look at the springs and levers that move the light assemblies. One lever has to be pushed back, like over center, and it will release the unit and the light assembly will close. You might have to push it down a little. You can also push up the closed light from below. Hope this helps.
Old Jan 25, 2004 | 12:23 PM
Jim Strathearn
Thanks for the quick replies! :thumbs:
Old Jan 25, 2004 | 12:26 PM
Larsson's Avatar
Larsson
May I hijack this thread and ask a similar question:
Is it possible to open the headlights with the engine off?
Just done simply try to push them up but they seemed stuck, it's a -72 btw.
Old Jan 25, 2004 | 12:29 PM
Phil Zell's Avatar
Phil Zell
Default Re: Close headlights manually (Larsson)
JUST MAKE SURE THAT YOU RAISE THEM SLOWLY AND THEY SHOULD STAY UP
Old Jan 25, 2004 | 08:07 PM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
If you reach up under the front, you should be able to feel the springs that hold the mechanism open/closed. Find one of the springs and pull straight down. I can't remember which spring, I've done it by feel too much to remember which it is.
Old Jan 25, 2004 | 08:10 PM
RHD '68 L89's Avatar
RHD '68 L89
If you still had the chrome bumper you can reach under the bumper (above the grill) and lift the headlight assembly a little. you can then get you fingers under the lip and lift it the rest of the way.
With the later front you will have to crawl under the front. It will do no damage to the system because the actuators are vacuum not electrical.
:cheers:
To Close headlights manually
