Underbody Aerodynamics...
Old Jan 30, 2004 | 07:31 PM
  #81
comp's Avatar
comp
Default Re: Underbody Aerodynamics... (burners)
burners; are you using pre-preg? i only have some basic composit books,
got any good reference books i should buy.
Old Jan 30, 2004 | 07:37 PM
  #82
ZD75blue's Avatar
ZD75blue
Carbon fiber is going for (depending on the weight) $16 to $31 a yard.
ZD75blue, at the moment the leading edge is rounded. Once it is in place I will get a better idea of what needs to be blended to have, perhaps, a more gradual transition or a sharp edge. As you know, the air under here is pretty turbulent so subtle edges wont do a lot but it is important to get it going out the back as straight as possible.
Yup...
One of the concerns I have is to not acomplish creating a smooth transition from the air going under the car to the pan in the back... if you make a wall for the air to go around you may cause lift! If you dont put a wall or curve the pan up in the front you do create a parachute because your diverting the air into an corner. And if the pan is flat from the front to the back, you dont provide downforce by creating a low preasure point.
Flat pan = less drag
Sloped pan = drag or lift
Air scoop = more drag! :crazy:
Old Jan 30, 2004 | 11:24 PM
  #83
comp's Avatar
comp
Default Re: Underbody Aerodynamics... (ZD75blue)
also need book/manual on vac. baging, making own etc. :thumbs:
Old Jan 31, 2004 | 09:33 AM
  #84
ZD75blue's Avatar
ZD75blue
Default Re: Underbody Aerodynamics... (comp)
Yup... At the moment I'm thinking its a toss up between fiberglass and aluminum! A foam mold for one and hammering out the other... but weight is the enemy as well! :cheers:
Old Jan 31, 2004 | 09:54 AM
  #85
comp's Avatar
comp
go on a diet :lolg: :lolg: :lolg: i got an extra 30 HP I'M carrying around
if i don't eat i save money, money saved is more PARTS :party: and
i can afford those books i need :thumbs: :thumbs: :thumbs:
Old Jan 31, 2004 | 01:14 PM
  #86
ZD75blue's Avatar
ZD75blue
True... But if your adding weight for the sake of reducing something else... I'd rather add less weight and achieve the same goal! :cheers:
Old Jan 31, 2004 | 03:32 PM
  #87
comp's Avatar
comp
i try to lose wieght every where but may wallet......
Old Jan 31, 2004 | 10:50 PM
  #88
ZD75blue's Avatar
ZD75blue
Me too... Alot better to cut off without sacrificing anything then to sacrifice da bread to save weight in more then one way! :iagree:
Old Jan 31, 2004 | 11:45 PM
  #89
comp's Avatar
comp
oh ya' i'm serious about the books.... i can drop a meal-a-day :thumbs: it's
brain food
Old Feb 1, 2004 | 11:09 AM
  #90
ZD75blue's Avatar
ZD75blue
brain food
Do Whaaat? Drop eating?!?! Man thats my second favorite thing to do! First being sleep... :jester
Old Feb 1, 2004 | 11:33 AM
  #91
comp's Avatar
comp
oh i love to eat to, thats why there is more of me,,, i look like a VARY rich
man in some country's :lolg: :lolg: now sleep :bs i don't enjoy that much,
we waste 1/3 of our live's doing it :banghead: thats a lot of time for watchin'
tv, cars, women, kids, making money, did i say cars and women :lolg: :lolg:
