Installing Comp Cam 282 ...Break in?
Old Jan 27, 2004 | 11:57 PM
Clown Puncher's Avatar
Clown Puncher
Default Installing Comp Cam 282 ...Break in?
How should I break in a new comp 282 cam? Anybody have any good suggestions?
Old Jan 28, 2004 | 12:47 AM
comp's Avatar
comp
Default Re: Installing Comp Cam 282 ...Break in? (Clown Puncher)
didn't it come with instru.
Old Jan 28, 2004 | 08:44 AM
bs82vette's Avatar
bs82vette
Default Re: Installing Comp Cam 282 ...Break in? (comp)
Instructions with mine run at 2000 rpm for 20 minutes
Old Jan 28, 2004 | 09:52 AM
dmrodco's Avatar
dmrodco
Default Re: Installing Comp Cam 282 ...Break in? (bs82vette)
:iagree: thats the standard breaking proceedure. if you dont you'll be VERY sorry
Old Jan 29, 2004 | 04:09 PM
marshrat99's Avatar
marshrat99
:iagree: with everyone. The only suggestions I'd make is 1) check all fluid levels prior to beginning the break in; 2) have a garden hose ready just in case you need to spray the radiator if it starts running a little too warm; and 3) have an ice cold six pack of your favorite beverage to consume during the 20 minutes while you're just standing there with nothing to do. :cheers:
Old Jan 29, 2004 | 08:02 PM
bigvette1's Avatar
bigvette1
Default Re: Installing Comp Cam 282 ...Break in? (marshrat99)
Get all the fluids full and prime the engine well so you see oil flowing out of the rockers through the valve cover holes. Hope you lubed the heck out of the cam and lifers.
Bring her to #1 TDC and set timing at about 8-10 degrees so it will fire quick. Prime the carb.
When it starts bring it to 2000-2200 rpms and hold it there for at least 20 -25 minutes. Vary the rpms some +/- 100 or so but don't go below 2000. After this back it down, set the timing and idle and let it cool. This will make for a happy cam and a happy you. A burnt lobe sure makes a crappy day.
To Installing Comp Cam 282 ...Break in?
