Torque Spec.
Old Jan 28, 2004 | 03:50 PM
Tom Johnson's Avatar
Tom Johnson
Default Torque Spec.
What is the torque spec. for the exhaust manifold nut that tightens the flange for the dognut gasket?
Old Jan 28, 2004 | 06:03 PM
Jvette73's Avatar
Jvette73
Default Re: Torque Spec. (Tom Johnson)
I dont think there is a tq spec for that. It needs to be tight enough to make a seal and thats it. If you continue to tighten it further it will eventually start to bend the flange on the pipe. Just make em good and snug and alternate around as you tighten so as not to make the flange shift crooked.
[Modified by Jvette73, 5:04 PM 1/28/2004]
