While I'm at it......
Old Jan 29, 2004 | 05:33 PM
motown 71's Avatar
motown 71
Default While I'm at it......rotor thickness
Rebuilding the front end, was wondering what the thickness of my rotors should be. I don't know how old they are but while it's all apart, if they are marginal I might as well replace while I'm replacing the bearings and races.
Thanks !
[Modified by motown 71, 10:33 PM 1/29/2004]
Old Jan 29, 2004 | 07:18 PM
motown 71's Avatar
motown 71
Default Re: While I'm at it......rotor thickness (motown 71)
Got off my butt and looked up this in the books......
Minimum for pre 82 is 1.215 with run out not exceeding0.005
'82 minimum is 47/64
Old Jan 29, 2004 | 08:05 PM
comp's Avatar
comp
put new on it's only money :lolg:
Old Jan 30, 2004 | 12:49 PM
RMVette's Avatar
RMVette
You're getting into a dangerous area of "while I'm at it" syndrome! :lol:
Old Jan 30, 2004 | 04:33 PM
Todbo's Avatar
Todbo
Default Re: While I'm at it......rotor thickness (RMVette)
:iagree:
that's an expensive phase
Old Jan 30, 2004 | 07:56 PM
motown 71's Avatar
motown 71
Default Re: While I'm at it......rotor thickness (Todbo)
Yep, I'm learning this part well......
Started with the front end rebuild, while I have room with a-arms out
lets replace some gaskets, oil pan, timing cover, fuel pump,
Hey let's get a new radiator.......can't put shiny rad. in with that ould iron water pump.......
I think new springs shall be ordered tomorrow..................
:crazy:
Old Jan 30, 2004 | 08:16 PM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
A couple of years ago, I started a fuel filter change on my '77. Six months later, I had a new engine, new front end, detailed firewall, new sound system....
:lolg:
To While I'm at it......
