The ZZ383 really isn't any different than any other motor. I guess your question then is: will a single plane intake fit under a stock hood. If the search function worked, you could probably get your answer pretty quickly. Hopefully someone will come along who knows the answer.
The Edelbrock Vortec RPM fits w/ dropbase & Holley w/ 73-79 med.rise hood. That intake is about 1" higher, the L-88 hood is 7/8" higher than the med. rise hood. Depending on your setup, the RPM which fits may be better.
