69 and ZZ3 intake hood clearance
Old Jan 30, 2004 | 09:27 PM
MCMLXIX's Avatar
MCMLXIX
Default 69 and ZZ3 intake hood clearance
I just perchased a ZZ3 intake manifold. I am using a Qjet with the stock drop base air cleaner and want to keep a 3" filter. Is it going to clear the small block hood?
Old Jan 30, 2004 | 11:25 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: 69 and ZZ3 intake hood clearance (MCMLXIX)
I think the ZZ3 and ZZ4 are basically the same manifold. I haven't had any problem with a quadrajet and stock air cleaner and SB hood clearance.
Old Jan 30, 2004 | 11:59 PM
MCMLXIX's Avatar
MCMLXIX
Default Re: 69 and ZZ3 intake hood clearance (Smokehouse69)
Thanks smokehouse.
Its looks to be quite a bit taller than my stock manifold and almost as tall as a LT1 manifold and I was hoping that it would fit with out having to get a big block hood.
To 69 and ZZ3 intake hood clearance
