68 Steering Box needs replacing
Old Jan 30, 2004 | 10:41 PM
Darrell's 68's Avatar
Darrell's 68
Default 68 Steering Box needs replacing
My steering box in my 68 is in need of rebuilding. I have seen various suppliers that rebuild these boxes, all at different prices ranging from $125 to $225. Can anyone personally recommend a supplier that they were happy with and certainly any that I should stay away from? Thanks for the help. :chevy
Old Jan 30, 2004 | 10:52 PM
71'AirStrike's Avatar
71'AirStrike
Default Re: 68 Steering Box needs replacing (Darrell's 68)
:lurk: for my 71
Van steel has a good rep on this board, havent bought anything from him/them tho
Old Jan 31, 2004 | 02:30 AM
R. Bruno's Avatar
R. Bruno
Bair's does excellent work. :yesnod:
Old Jan 31, 2004 | 08:39 AM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
Default Re: 68 Steering Box needs replacing (R. Bruno)
:iagree: They did my '68's steering box for $159-came out perfect!!!
Steering box is just below the right trailing arm. :yesnod: Pic shows some assembly required, batteries not included :lolg:
[Modified by Paul Borowski, 7:41 AM 1/31/2004]
Old Jan 31, 2004 | 09:47 AM
OkeeGuy's Avatar
OkeeGuy
Default Re: 68 Steering Box needs replacing (Paul Borowski)
one word...STEEROIDS!
if you can afford it, its the ONLY way to go...
if you dont want to do that...i bought one from Zip once...great service there!
Old Jan 31, 2004 | 10:39 AM
GTR1999's Avatar
GTR1999
If you're going to rebuild it yourself then get a kit from Bair's. If you're going to send it out then Bairs or Van Steel would be good.
These are not too hard to rebuild but you should check a couple of areas to be sure they covered. If you want more info IM and I'll go through it with you. Price depends on the job done. I usually end up making bushings to hold the pitman arm side play to under .002", this requires more time and material then a standard rebuild would.The bushings in the kits are too loose most of the time.
See if the search is working too,there was a lot of sterring box info there.
Gary
To 68 Steering Box needs replacing
