75 fuel tank vent??
Old Feb 1, 2004 | 04:11 PM
kaz1961's Avatar
kaz1961
Default 75 fuel tank vent??
I posted previously about a line in my engine compartment that I thought was a vacuum line cause it was routed to the heater core area. I now think that it is a fuel vent as it is fuel line and you could smell gas from it. Does anyone know where this belongs? It is the exact length to reach the vapor canister if you reroute it in the engine compartment. Is it supposed to hook up to something near the canister? Thanks for any help. :confused:
Old Feb 1, 2004 | 04:15 PM
KenSny's Avatar
KenSny
Default Re: 75 fuel tank vent?? (kaz1961)
vent is on left side of top of tank and goes to the cannister. However mine runs a short length of rubber hose to a steel line that goes thru the frame and a short piece of rubber tube from the other end to the cannister. Not rubber all the way. Two lines on right side go to fuel pump lines. Got mine apart now......
