Too much carburetor?
Tuning for Beer Tour comes to Europe this summer. I'll be in Oslo and Trondheim in July. I could certainly make a run over to Sweden at the same time. Let me know if there's interest.
It's from the other forum I hang out on when I'm not out here: http://www.corvetteforums.net/6/ubb.x
Also, check out 96LT4's page http://www.96lt4.com/SMILIES1.html
Keep in mind through all this that GM installed 750 cfm Q-Jets on engines 250 cid and bigger (the OHC Pontiac was 250 inches with a 750 Q-Jet). I spite of common misconceptions, the Q-Jet is NOT a vacuum secondary carb: It is a mechanical secondary carb with an airvalve to allow the secondaries to come in without the use of a secondary accelerator pump (a secondary pump would cost more).
I have run back-to-back tests of 650 and 750 carbs on engines down to 302 cubic inches (take a look at this monthÂ’s issue of Hot Rod Magazine: There is an article in there by Matt King on computer simulation versus actual power. The engine in the article is a 302 Ford. We ran that engine with a 650 and a 750 BG mech sec carb. The 750 consistently produced 5 more hp across the rpm range, and the results in the article are with the 750 mech sec carb as shown in the photo). Dyno runs typically start the pull at 3000 rpm, where the engine is placed under massive load and the carb is popped right open to WOT. On every run I have made, a 302, 327, 350 and 383 will take a 750 mechanical secondary carb slammed right open to WOT at 3000 rpm without any bog or hesitation, and it will consistently produce better power across the rpm range than a 650 carb.
However, it is true that a smaller engine can only consume a given amount of air at any given speed. Opening the throttle plates suddenly on a small engine running at low RPM, the engine cannot consume the air that is suddenly made available to it so the manifold pressure suddenly rises. This disrupts the vacuum signal and causes the air fuel ratio to go out of whack. To compensate, a double pumper squirts in extra fuel untill the RPM of the motor comes up high enough to use the air that is available. A vacuum secondary system simply does not open the secondary throttle plates until the engine is capable of consuming the air that is available from the secondaries.
I tried a carb swap on my '69 Z28 (302 cid, incidentally) many years ago on the thought that it was overcarbed from the factory (those Detroit engineers don't know nothin', huh? If they print it in a magazine it must be true. ;)). Swapping on a 650 vacuum secondary carb from the original 780 vacuum secondary carb killed the top end and killed the throttle response as well. It felt like I had to step further in to it to get similar performance. I did! Needless to say I gave the 650 back to my buddy and ran with the 780 from there on out. Lesson learned.
Going with a 750 with vacuum secondaries will give you fine performance. The carb will only give you the air flow YOU NEED. A DP would work too but the pump shot would have to be tweaked a bit to get rid of any bog from a sudden WOT accel from off-idle. :thumbs:
I have to join those who say your car will run fine with a 650 vaccum secondary carb.
You could put a 750 or even an 800 up there but I think the 650 will provide you with crisper throttle response across the RPM range where the engine will be seeing most of its time and somewhat easier tuning.
Of course if you're just interested in WOT, go for however big a carburetor as you can afford.
I'm printing this entire thread out, and saving in a notebook with other tech articles. You never know when the search function fails, and/or there is a problem viewing archived threads.
I just went out with G-Tech, and first ran a 0-60mph time of 4.94 seconds.
Then, I did a 1/4 mile run in 13.46 seconds @ 99.8MPH. I will say that during the 1/4 mile run, two things hurt me. First, I was running out of road so I backed off a little early. :lol: Second, I hit several flat spots at WOT around 5K, either because of the carburetor, fuel pump, or timing. I guess that's evident in my mph time. Anyways, that's my times for a stock Q-Jet, 2101 intake, and who knows what timing on an otherwise modified engine.
Once I set the timing, and install the Demon and RPM intake, I'll make another run and see what happens. High 12's possible :confused:
BTW, with 3.70 gears and 3550lbs total weight, how much hp is my engine making?
Chuck
I'm running a TH350 with a 2000 stall convertor, so no worry about the clutch.
Even so, that's a good idea. :cheers:
[Modified by Sling Blade, 8:43 PM 2/13/2004]
My stock 71 is mostly for cruising and even the occasional long distance trip, how will vacum vs mech carbs affect fuel economy? Does the CFM rating also affect this?
