Detailing Engine
Old Feb 3, 2004 | 03:01 PM
YZ450FRACER165's Avatar
YZ450FRACER165
Default Detailing Engine
WHat is the best way to go about detailing the engine. Can I just spray simple green or degreaser onto the engine and then hose it off? This is probably another one of those "i AM STUPID" QUESTIONS :lol:
Old Feb 3, 2004 | 03:15 PM
LOTAHP's Avatar
LOTAHP
Default Re: Detailing Engine (YZ450FRACER165)
Pull it out (the engine :eek: ) :lolg: Simple Green uncut is fine then hose ot off and wipe it down. Gunk is good and has that "clean chemical" smell :D Grease Lighning is also good. Whatever you use, use at full strength. :thumbs:
Old Feb 3, 2004 | 03:26 PM
YZ450FRACER165
Default Re: Detailing Engine (lotahp)
Hosing the engine off with a stream of water wont hurt it? Just want to be sure
Old Feb 3, 2004 | 03:50 PM
LOTAHP's Avatar
LOTAHP
Looking at your profile I see now you are new to this. That's OK. Hosing the engine down with a hose is OK but it does take some "common sense". Certain places you can use more pressure ( around the main crossmember & cntol arms) and some places be careful ( around the distributor & carb) If your careful you DO NOT have to bag up the carb. or distributor. But just a little hint... The more careful you are the easier the clean up will be.
Old Feb 3, 2004 | 05:10 PM
YZ450FRACER165
That's what I figured, but I 'll bag everything up so I don't get stupid! :withstupid:
Old Feb 3, 2004 | 08:46 PM
fjetb's Avatar
fjetb
YZ...I'm with you...that is exactly something I've been wanting to know.
Thanks guys. :cheers:
Old Feb 3, 2004 | 11:58 PM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
I think a good place to start, is at the coin op car wash. I take a can of Gunk Engine Cleaner with me, and I start there. That way, most of the crap goes on someone elses property.
Once the bulk of the garbage is off, I take the car home and do the detail stuff. A jar of mineral spirits and a toothbrush works great. It will cut right through grease.
As others have pointed out, be careful of the carb and the distributor. Also, you really don't want to douse a hot engine with water. Try to stay away from the cylinder heads. Over spray or light spray is not a problem (othewise, how would we be able to drive in the rain?).
To Detailing Engine
