Can this be fixed?
Old Feb 3, 2004 | 05:46 PM
wacked's Avatar
wacked
From: If the world didnt suck, we would all fall off. Troy,Ohio.
Cruise-In VI Veteran
St. Jude Donor '04-'05-'06-'07-'08
Default Can this be fixed?
This is what i found when i took the tape off my engine wiring harness :cry
Old Feb 3, 2004 | 06:01 PM
NHvette's Avatar
NHvette
Default Re: Can this be fixed? (wackedvette)
Looks like you have a bit of customization there.
Do you have a tilt-nose ?
I can't help with the wiring from what I see .... Does/did it work before 'untaping' it ?
I think you are looking at your horn relay ... relocated from the front of
the drivers side of the engine. I thi8nk the early models used this as a power
distribution point.
[Modified by NHvette, 6:04 PM 2/3/2004]
Old Feb 3, 2004 | 06:16 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Default Re: Can this be fixed? (NHvette)
:eek:
Old Feb 3, 2004 | 06:26 PM
79VetteMike's Avatar
79VetteMike
tape it back up, but this time use duct tape. :lolg:
Old Feb 3, 2004 | 06:43 PM
wacked's Avatar
wacked
Default Re: Can this be fixed? (79VetteMike)
The fix it all. :lolg: :lolg: :lolg: :lolg:
Yes it has a tilt nose.
Old Feb 3, 2004 | 06:56 PM
killain's Avatar
killain
Oldtimer
There should be a Junction block on the firewall. It has a 7/16 or 3/8 bold head in the middle, it splits in half. You can get a front section from 'Lectric limited' and go from there if it's (the damage ) is only in the engine bay.
Old Feb 3, 2004 | 07:00 PM
wacked's Avatar
wacked
Default Re: Can this be fixed? (killain)
The only thing that looks like that is one in the 2nd pic.
Old Feb 3, 2004 | 08:41 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I believe that is called a Kerney(Spelling???). Usually they are used to group grounds together. Shouldn't really be used there. I think it would eventually give you problems.
Old Feb 3, 2004 | 08:44 PM
Paul L's Avatar
Paul L
My opinion is no. Avoid future problems by buying a new engine harness.
Old Feb 3, 2004 | 08:47 PM
wacked's Avatar
wacked
Default Re: Can this be fixed? (Eddie 70)
What should I do? I cant afford(sp) a new one.
Old Feb 3, 2004 | 08:52 PM
stpman's Avatar
stpman
Default Re: Can this be fixed? (paul67)
:iagree: if you don't do it now you'll have to down the road anyway (no pun intended)
Eddie70 close it's called a Burndy for splicing cables and your right it shouldn't be used there.
Steve :steering:
Old Feb 3, 2004 | 09:01 PM
Paul L's Avatar
Paul L
Give these people a call. The price for just the engine harness may be within your budget.
http://www.lectriclimited.com/
Old Feb 3, 2004 | 09:07 PM
Fleetwood's Avatar
Fleetwood
Be careful reusing wiring in poor condition,thats how fires start.Like you I could not afford new harnesses,I removed the harness completely,layed it out on my work bench,& replaced all the wires with new using the old harness as a template,including new connectors.Not a hard job,but you will definately need a good wiring diagram.Use none adhesive tape to tape each loom up this avoids a sticky mess if you need to replace wire in the future.
Most Auto stores sell the correct gauge wire as well as the correct connectors.Just my opinion of what I did.
Neil.
[Modified by Fleetwood, 8:10 PM 2/3/2004]
Old Feb 3, 2004 | 09:25 PM
wacked's Avatar
wacked
Default Re: Can this be fixed? (Fleetwood)
Could any one scan it? I know the book cost's a lot. I want to do this my self.
I will pay you back some how, I promise.
Old Feb 3, 2004 | 09:59 PM
wacked's Avatar
wacked
I booked marked the site, I will call them tomorrow:)
Thanks.
Old Feb 3, 2004 | 11:06 PM
corvtt1969's Avatar
corvtt1969
if you cant duct it, F#*k it!!
Old Feb 3, 2004 | 11:08 PM
wacked's Avatar
wacked
Default Re: Can this be fixed? (corvtt1969)
I just want to fix it.
To Can this be fixed?
Old Feb 4, 2004 | 02:19 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Can this be fixed?
:nono:
Old Feb 4, 2004 | 08:08 AM
Pauld's Avatar
Pauld
Default Re: Can this be fixed? (Desertdawg)
Looks dangerous to me, as already stated, bad wiring can cause serious problems and fires. If you can, just bite the bullett and get a new loom, safer and you won't have to worry.
Old Feb 4, 2004 | 08:15 AM
comp's Avatar
comp
Default Re: Can this be fixed? (Pauld)
i'd let it sit and save , rather than me sit and watch it burn...... :banghead:
