Temperature sending unit for 79
Old Feb 7, 2004 | 04:24 PM
bodaman69's Avatar
bodaman69
Default Temperature sending unit for 79
I need a temp sending unit for my 79. Parts store doesn't carry one but chevy does but it's 45$. I tried a generic one for a SBC but the gauge just pegged out. Anybody know of one that will interchange ?
Old Feb 7, 2004 | 05:37 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Default Re: Temperature sending unit for 79 (bodaman69)
I have gotten them from NAPA store and Auto Zone.
Old Feb 7, 2004 | 05:39 PM
Green76's Avatar
Green76
Go to your local Autozone they can order one for you.
Ulf
Old Feb 8, 2004 | 07:50 PM
bodaman69's Avatar
bodaman69
Default Re: Temperature sending unit for 79 (Green76)
I went to autozone and Orielly's and they didn't have it and could not even order it. They told that part was unavailable! :banghead:
Old Feb 8, 2004 | 08:01 PM
Paul L's Avatar
Paul L
Take a little bit of fine sandpaper and clean up the female brass connection to brightness. Put a little bit of WB-40 on the connection and reinstall. My connection used to peg off right after 5 months of winter storage and that was my routine solution.
Old Feb 8, 2004 | 10:13 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Try this place http://www.lectriclimited.com/switch...al_devices.htm
I used to know the ohm rating at temperature for the temperature sensors, but I can't find it. If you can find out what the rating is you should be able to get a parts store to cross reference it for you. Napa and most other parts stores actually have a book that you can look for sensors by the ohm reading at a specific temp.
Old Feb 9, 2004 | 06:57 AM
guppie's Avatar
guppie
St. Jude Donor '08
I bought one from Chevy for $8 or $9. Is the 79 different than 78?
To Temperature sending unit for 79
