Painting Rocker Panels
Old Feb 8, 2004 | 08:50 PM
YZ450FRACER165's Avatar
YZ450FRACER165
Default Painting Rocker Panels
I have an 80' and my rocker mouldings are getting kinda ugly. Should I just repaint them, and which kind of paint should I use, or should I just go out and buy new ones? Does any one know of a paint that looks like chrome, as for some reason, the brown and gold-platinum paint likes chrome. Thanks!!
Old Feb 8, 2004 | 09:15 PM
Stingray 77's Avatar
Stingray 77
Default Re: Painting Rocker Panels (YZ450FRACER165)
r u talking about the aluminum panels/strips or the body itself? :skep:
Old Feb 8, 2004 | 09:58 PM
YZ450FRACER165
Default Re: Painting Rocker Panels (Stingray 77)
The aluminum panels under the doors. They are black on the 1980.
Old Feb 8, 2004 | 10:48 PM
MN-Brent's Avatar
MN-Brent
I painted mine with gloss black Rustoleum Appliance Epoxy spray paint from the Home Depot. Stronger than enamel and slightly more glossy than OEM flat/satin rocker paint. No primer neccesary, just sand, clean with brake cleaner and shoot.
Smells real funky so keep area well ventilated and it takes 24 hours to dry properly. Looks beautiful and so far no chips at all. I highly recommend it.
Brent...
Old Feb 8, 2004 | 10:54 PM
YZ450FRACER165
Default Re: Painting Rocker Panels (MN-Brent)
Thanks Brent. How many cans did you use? I will go there tomorrow, and will let you know the results!!!
[Modified by YZ450FRACER165, 10:54 PM 2/8/2004]
Old Feb 8, 2004 | 10:59 PM
MN-Brent's Avatar
MN-Brent
I would get 2 since they are only $5-$6 each. I think I did 2 coats on each front and 1 coat on the back side (which was done first).
If I remember I had to go to a few stores since Black was a hard color to find. Green and White were the most common. You might have to try a local/regional hardware store too if the Home Depot isnt carrying that color.
Brent...
Old Feb 8, 2004 | 11:56 PM
Shark Racer's Avatar
Shark Racer
If you want it to be really trick, and really easy to maintain, take it to a metal processor and have them remove all the sulfur anodizing, then have it re-anodized black. Remember, correct black panels have a polished aluminum strip above the screw rail.
I took a pair of 79 panels and had them stripped when I wrecked one of my 78 pace car panels. Turned out great.
However, don't go with repops. They just don't fit.
-Steve
Old Feb 9, 2004 | 06:40 AM
UKPaul's Avatar
UKPaul
Default Re: Painting Rocker Panels (Pacin'California)
:iagree: I got mine black anodized & they look great. But you MUST make sure that all the original anodizing is removed, otherwise the black won't cover those parts (all anodizing does is to basically put a layer of oxidized aluminium on the surface & this layer is colored with a dye. If there a layer of existing oxidization present then you can't cover it with another). One big bonus with the anodized surface is that it doesn't chip as easily as paint. Here's a pic of mine, but it doesn't really show how nice they look.
:cheers:
Old Feb 9, 2004 | 07:24 AM
Racer16k's Avatar
Racer16k
Has anyone done them in a charcoal color or the gray like a TT II wheel center? I was thinking of trying that color when I get my new wheels.
Old Feb 9, 2004 | 11:06 AM
Stingray 77
ok what i did is by that glossy rust alumiom stiff theres a new another name for it u can buy at ace hard where u can buy a pint or gallon i started 2 use that on my frame what i did is sand/grind sown the frame 2 get surface rust off of it then i used a meter cleaner same stuff u use 2 wipe down car with before u paint it. then i took a bruse and apllied it on it its hard 2 2 without a left unless u have teh car jacked up in the air. i need 2 finsh mine after i get this house im buying that has a garage its hard 2 jack up in sand lol :crazy:
Old Feb 9, 2004 | 02:45 PM
LiveandLetDrive's Avatar
LiveandLetDrive
Yikes man, abreviating things and talking in one continuous sentance makes that a little unreadable!
How permanent is an anodized finish?
Old Feb 9, 2004 | 02:55 PM
Twin_Turbo's Avatar
Twin_Turbo
Get paint stripper and remove the ugly black finish, there's nice shiny aluminium under there that will really shine with a bit of polishing
These were black too
[Modified by Twin_Turbo, 1:58 PM 2/9/2004]
Old Feb 9, 2004 | 10:29 PM
YZ450FRACER165
Default Re: Painting Rocker Panels (Twin_Turbo)
I like that aluminum. But I like how the black looks. Thanks for all the great ideas!!!! :seeya
Old Feb 9, 2004 | 11:05 PM
Stoge's Avatar
Stoge
Translation for those that need it:
Here is what I did:
First, I purchased the glossy rust aluminum stuff. There is another name for it, but I am not sure of the name. You can purchase it at Ace hardware. It can be purchased either by the pint or gallon.
I started to use it on my frame. What I did is sand / grind down the frame to get the surface rust off. Then, I used a meter cleaner (same stuff you use to wipe an object down with before you paint it). I took a brush and applied the meter cleaner. It is difficult to do unless you have the car jacked up in the air.
I am hoping to finish mine in the garage after I purchase my new home. I find it terribly difficult to jack the car up in sand. :lol: :crazy:
(and yes, I am being a :jester :conehead :hat )
:p:
Old Feb 9, 2004 | 11:18 PM
MN-Brent's Avatar
MN-Brent
Default Re: Painting Rocker Panels (Stoge)
You can speak Jive? :jester
Old Feb 9, 2004 | 11:26 PM
Stoge's Avatar
Stoge
Fo shizzle!
:lolg: :lolg: :lolg:
To Painting Rocker Panels
