Torque-Thrust D on Shark
Old Feb 9, 2004 | 10:02 AM
Rocket69's Avatar
Rocket69
4th Gear
Default Torque-Thrust D on Shark
Greetings. Am wanting to go "period correct" with my '69 by adding TT Ds. Is anyone running the 15"x 8 1/2" rim (3 3/4" backspacing; -24 mm offset)? The American Racing Web site does not list the "D" under their application guide for '68-82 -- only theTT IIs. As near as I can figure a stock rally has 4" backspacing and -18 mm offset. Will the Ds fit within the wheelwells to keep the stock look? (I'm keeping the 225/70/15 BFGs.) Thanks!
Old Feb 9, 2004 | 10:23 AM
Paul L's Avatar
Paul L
Default Re: Torque-Thrust D on Shark (Rocket69)
You will find that the modern Ds (the spokes) will not clear the calipers. I went with the IIs for that reason.
You can see the bend in the spokes for caliper clearance.
Hopefully Zwede will see the thread and give you more expert advice. This is his car.
[Modified by paul67, 10:26 AM 2/9/2004]
[Modified by paul67, 10:46 AM 2/9/2004]
Old Feb 9, 2004 | 10:51 AM
Scooter70's Avatar
Scooter70
Default Re: Torque-Thrust D on Shark (paul67)
Try Vintage Wheel Works (they do a repro that's supposed to clear) or the American Racing CL205 (which is a TT2 with the center powdercoated grey). I want to do the same thing on my car eventually.
Old Feb 9, 2004 | 11:08 AM
L824spd's Avatar
L824spd
Do the TT's come in a 16" that will work on our toys?
Old Feb 9, 2004 | 11:15 AM
Rbbmoose427's Avatar
Rbbmoose427
I'm real familiar with this issue - as I just went through this issue with wheels for my 1970 mustang.
If you get the 1 piece American Racing Torque Thrusts you are stuck with their 3 3/4 back space - which wasn't right for my 'stang.... If you order their more expensive 2 piece wheels - you can get any back space you want - They take a couple of months to come in and cost an extra $50 or so, but it was worth it for me... The two piece wheels are almost exactly the same but come with a metal center instead of the cheap plastic ones.
Ray
Old Feb 9, 2004 | 11:39 AM
Paul L's Avatar
Paul L
Default Re: Torque-Thrust D on Shark (L824spd)
Yes they do. Search on product code AR2056800.
http://www.wheelsforless.com/search_result.asp
[Modified by paul67, 11:40 AM 2/9/2004]
Old Feb 9, 2004 | 03:00 PM
lvrpool32's Avatar
lvrpool32
I wanted the same look for mine, but because the original Torq thrust D's are no longer available (they had the spokes clearenced in the back to clear the brake calipers) I went with the AR 200S (daisey or coke wheel) which is another period wheel.
A friend of mine tells me that the "original" Torq Thrust D's where jsut re-introduced at the SEMA show, so you may want to call AR direct and find out.
Nick
Old Feb 9, 2004 | 03:53 PM
mfgaffney's Avatar
mfgaffney
Go to Americanracing.com, they have a great interactive website, where you can picture any of their wheels on your ca, in your color. They also have a tech site, where you can email questions.
Old Feb 9, 2004 | 06:56 PM
no_radio's Avatar
no_radio
I have had the Vintage Wheel Works 16" version for about 3 years now, and I love them. I get the most compliments on my wheels and paint, the wheels make the car.
Jeff
Old Feb 9, 2004 | 10:12 PM
trw's Avatar
trw
I went with the old Appliance Wheels. They fit without spacers.
But, they are hard to find and cost about the same as new TTDs.
Terry
(click pic to enlarge)
Old Feb 10, 2004 | 10:28 AM
Scooter70's Avatar
Scooter70
Default Re: Torque-Thrust D on Shark (trw)
:thumbs:
Old Feb 10, 2004 | 01:04 PM
71coupe's Avatar
71coupe
This is the a "new" wheel in the AR website, TTO series 309:
It doesn't look a whole lot different from their TTD series 105 model:
As stated, the brake caliper clearance is a big problem. In any case, I would contact the manfacturer as liverpool said.
The original American Racing Torq-Thrust (which is no longer made) was designed in the mid 60's. It was primarly designed to fit disc brake Vettes, the spokes had a slight outward curve to them as seen from these photo:
Their is good info on this page as well:
http://www.roadsters.com/wheels/
Radir wheels may fit: http://www.radirwheels.com/
Good luck :cheers:
BTW - Welcome to the forum :seeya
[Modified by 71coupe, 1:17 PM 2/10/2004]
Old Feb 10, 2004 | 01:26 PM
71coupe's Avatar
71coupe
TRW - that wheel and tire combo looks great on your car!
I think the tall sidewalls with the 15" wheels looks perfect on early sharks or midyears.
[Modified by 71coupe, 1:28 PM 2/10/2004]
Old Feb 10, 2004 | 08:03 PM
John 65's Avatar
John 65
Paul, You did a super job on those wheels. They came out real nice :cheers:
Old Feb 10, 2004 | 08:35 PM
Paul L's Avatar
Paul L
Default Re: Torque-Thrust D on Shark (John65,80)
I am getting the Pirellis mounted on the TT IIs soon and then on to the car for April emergence from winter storage. I have not seen my 1967 since October. I am getting impatient as you can imagine.
Old Feb 13, 2004 | 07:55 PM
spikezz4's Avatar
spikezz4
Yes it can be done. We went to a CNC machine shop and had them make 4 custom spacers with the GM center flange. This way, they fit the same way every time. Unfortunately, we sold them for $250 for the set of four last year. It cost about $400 to have them blueprinted the first time, but much cheaper since the machine shop already has the numbers to dial in. We were running P225R70-15's.
Spike
Old Feb 14, 2004 | 06:58 AM
corvettejay's Avatar
corvettejay
my 73 had a set of tt's on it when I baught it 15x8.5 with no spacers I dont recall the name on the back but I think it was a.r. I took them off the vette
and put the wheels on my wife's 70 chevelle, they look great!
To Torque-Thrust D on Shark
Old Feb 14, 2004 | 11:00 AM
ccryder's Avatar
ccryder
Default Re: Torque-Thrust D on Shark (corvettejay)
I also have the Vintage Wheel Works 16's on all four corners. So far so good!
Old Feb 16, 2004 | 03:40 PM
Rocket69's Avatar
Rocket69
4th Gear
Hey thanks to everyone for your replies -- as a newbie I appreciate the attention! I'll be pursuing several of the leads suggested ...
Jeff
Old Feb 16, 2004 | 03:52 PM
Rocket69's Avatar
Rocket69
4th Gear
Default Re: Torque-Thrust D on Shark (lvrpool32)
Nick
Thanks Nick. Your friend is right: I found a press release where AR did introduce the Series 309 T.T.O. ("Torque Thurst Original") at SEMA last November. They're on the AR Web site, but don't say anything about what makes them different ("dished" spokes maybe?) from the TT D. Hope to find out more ...
Jeff
