dash lights
Old Feb 9, 2004 | 09:28 PM
guitar308's Avatar
guitar308
Default dash lights
hello, i am having a problem with my dash lights. they come on when i pull the light switch out , but i have to wiggle it a little and then it comes on and if i move it and little again it goes off. ne suggestions? thanks
Old Feb 9, 2004 | 09:36 PM
kenko74's Avatar
kenko74
Default Re: dash lights (guitar308)
I've had to replace my headlight switch twice in the last 8 years for a similar problem. The switch gets just a little loose at the contacts, I guess. After replacing the switch, the dash lights worked perfectly--for about 8 years.... :smash:
Old Feb 9, 2004 | 10:10 PM
guitar308's Avatar
guitar308
Default Re: dash lights (kenko74)
is there any way to repair the switch or clean the contacts without having to replace it?
Old Feb 10, 2004 | 09:53 PM
guitar308's Avatar
guitar308
well im tryin to take apart the dahs and have taken all the screw out, the dash wont come out but i can pry it back to see the light switch. how is this light switch removed cause it seems a lil odd. and what process did u go through to replace ur light switch. thanks
Old Feb 10, 2004 | 10:33 PM
wacked's Avatar
wacked
From: If the world didnt suck, we would all fall off. Troy,Ohio.
Cruise-In VI Veteran
St. Jude Donor '04-'05-'06-'07-'08
This is the release, pull the switch all the way out first. If you dont you'll haft to take it apart and fix it.
The second pick is the threaded screw type, it hold's the switch in place. I hope this helps you out:)
:EDIT SPELLING:
[Modified by wackedvette, 3:35 AM 2/11/2004]
Old Feb 10, 2004 | 11:11 PM
NOTHIN'LIKE'A'69''s Avatar
NOTHIN'LIKE'A'69'
you might want to lower your steering colum to remove the dash.... there are a few bolts holding the bracket under the dash... this will give you more room to play with...you will also need to disconnect all wiring to pull it... the switch is easy... just pull the **** rod out... be very carefull when installing the new one... dont push the rod in too hard or you can break the switch.... i've done this..... :cheers:
Old Feb 10, 2004 | 11:32 PM
Fleetwood's Avatar
Fleetwood
I repaired my switch.Just bend out the tangs on the side of the switch,& the black part that houses the contacts comes off.Just take note of the order in which the parts come off,there is a cam arrangement at the front which locks the interior lights on.The small spring that maintains contact pressure was broken on mine.I found a replacement spring,put it all back together after cleaning the contacts & it works fine.If your spring is alright you can increase the contact pressure by fitting a small washer under the spring in the recess that houses the spring.
Neil.
Old Feb 11, 2004 | 07:08 PM
guitar308's Avatar
guitar308
Default Re: dash lights (Fleetwood)
so i got the headlamp switch out from the side with some luck. i purchased a new one that cost 60. thanks all for your help.
Old Feb 11, 2004 | 08:04 PM
guitar308's Avatar
guitar308
so i have my dash apart and need to replace the dash left turn signal. how do u remove these bulbs with such small space? thanks
To dash lights
