81 control arm bushing help
Old Feb 9, 2004 | 09:48 PM
gravismaximus's Avatar
gravismaximus
Default 81 control arm bushing help
i have all 4 control arms out, i planed on putting in new bushings. my question is, is there a tool that gets the old bushings out without any damage to the control arms. what is the recomended way of doing it? :rant:
Old Feb 9, 2004 | 09:56 PM
Pedro'74's Avatar
Pedro'74
Default Re: 81 control arm bushing help (gravismaximus)
I think that a hole saw of appropriate size on a power drill would work---I used that to remove the strut rod bushings, and it worked great. That being said, I had mine out, and bailed out: sent everything to Van Steel, who did a beautiful job for a great price.
:cheers:
-Pedro
Old Feb 10, 2004 | 09:39 AM
Master Ho's Avatar
Master Ho
I saw some recent posts on this; some recommended drilling holes in the rubber bushings then pushing them out, others said to use a torch and burn them out. YMMV.
Old Feb 10, 2004 | 11:13 AM
lars's Avatar
lars
I have a complete "How-To" article on doing this. Drop me an e-mail and I'll send it to you:
V8FastCars@msn.com
Basically, they zip right out with an air chissel - no damage to the arms, and very easy to do. You knock the new ones in with some 3/4" drive sockets. The paper covers the process in detail.
Old Feb 10, 2004 | 04:14 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Default Re: 81 control arm bushing help (lars)
:lolg: :lolg: :lolg: If your lucky. They are not always that easy.
Old Feb 10, 2004 | 06:21 PM
Willis's Avatar
Willis
Default Re: 81 control arm bushing help (Pedro'74)
I did the control arms on my 81 and after hearing how much difficulty my friend had doing his grand prix control arms I just took them to the local tire shop and they charged me $10 per side to press them out, and press in the new polyurethanes from the energy suspension kit. Well worth my $20.
Old Feb 10, 2004 | 06:35 PM
NHvette's Avatar
NHvette
Default Re: 81 control arm bushing help (Willis)
I paid my (usually trustworthy) parts store machine shop to press mine out.
It cost me more than $20 ... and they F'ed up one of my control arms.
Forget drilling/hole saws for the lowers. That'll only work for the tops. Once
the rubber/inner shell is out of the tops, the cross bar can be slid out - and
you still need to press/knock out the outer shells.
If I were to do it again, I would follow Lars ... air chisel with a tip modified/ground
to grab the edge of the shell.
Going back in, I made some supports to brace the two ends of the arm - and
I had an 8 ton press that a friend let me borrow.
Good luck ... :seeya
Old Feb 10, 2004 | 07:35 PM
John 65's Avatar
John 65
Default Re: 81 control arm bushing help (Master Ho)
Thats how I got mine out, by drilling the rubber till its all gone. It take a little time but it works.
Old Feb 10, 2004 | 07:41 PM
motown 71's Avatar
motown 71
Default Re: 81 control arm bushing help (John65,80)
Burn baby Burn !!
I used a torch to remove the rubber, like cutting butter......Then I used
a socket of the approiate size and BFH. Was actually very easy with the rubber Gone !
:smash:
Old Feb 11, 2004 | 09:43 AM
lars's Avatar
lars
Default Re: 81 control arm bushing help (Van Steel)
Actually, they are. You just have to use the right technique. I was going over my records the other day, and I've done over 30 GM front end rebuilds using this technique, and I don't think it's ever taken me more than 2 minutes to pop out a bushing, no matter how badly rusted the sleeve was. The trick is to not try to hammer the bushing out by its outer lip: You have to get the tip of the air chissel onto the inner sleeve and dig into it. Once you hit the inner sleeve, it will pop right off the shaft with no problem at all, regardless of condition. You can then catch the outer lip and pop the outer shell out of the arm.
The reason I advocate this technique is for 2 reasons:
1. You can do it at home using nothing more than a good vise and an air chissel
2. There is no danger of twisting or bending the a-arm.
On number 2, I have seen shops completely destroy a-arms by supporting them incorrectly in a press and pushing on the bushing until the arm looks more like a pretzel than an a-arm. This is not to say that there aren't good shops and good people doing good press work. I just like doing things myself... you know: "If you want something done right..."
To 81 control arm bushing help
