Spare Tire Carrier Question
Old Feb 10, 2004 | 10:33 PM
Darrell's 68's Avatar
Darrell's 68
Default Spare Tire Carrier Question
I wanted to put a full size tire in my spare tire carrier, which for me is 235/60/15. However, it won't fit with 30lbs of air in the tire with the standard front bolts. Has anyone else run into this problem and how did you fix it? If you found bigger bolts, who sells them?
Old Feb 10, 2004 | 10:42 PM
Z-man's Avatar
Z-man
Default Re: Spare Tire Carrier Question (Darrell's 68)
:skep:
I thought a '68 would be the same as in '70 where the spare just sits in a big tub which, in turn, is bolted with a long, single bolt to secure the carrier from the rear. What are the "front bolts"?
Old Feb 10, 2004 | 10:48 PM
Darrell's 68
Default Re: Spare Tire Carrier Question (Z-man)
The bottom part of the carrier pivits on the two front bolts, and locks in place with the rear. If I were able to find longer bolts for the front, I think the tire would fit properly in the carrier.
Old Feb 11, 2004 | 06:15 AM
RHD '68 L89's Avatar
RHD '68 L89
I have a 235/60/15 in my carrier.
You don't need longer bolts, just remove the existing ones and put a nut on the thread. Screw them back in and use the nut to lock them about an inch out.
Works for me!
:cheers:
Old Feb 11, 2004 | 11:10 PM
Darrell's 68
Default Re: Spare Tire Carrier Question (RHD '68 L89)
Thanks!
To Spare Tire Carrier Question
