pumpkins R orange
Old Feb 11, 2004 | 09:42 AM
GATOR454's Avatar
GATOR454
Default pumpkins R orange
...well at least mine is now.
I wanted a little color in the rear end, the all black and silver seemed a little boring, so since I have this orange and blue thing going on I painted the differential orange.
I also got the driveshaft balanced, painted gloss black and spicer solid U-joints installed for $80, which seemed a pretty fair price for how it turned out.
I'm creating more point deductions daily!
David
Old Feb 11, 2004 | 09:43 AM
Fevre's Avatar
Fevre
Default Re: pumpkins R orange (GATOR454)
:thumbs:
Old Feb 11, 2004 | 10:00 AM
comp's Avatar
comp
Default Re: pumpkins R orange (Fevre)
i give ya' points :thumbs: but i'm a little off :lolg: :lolg:
Old Feb 11, 2004 | 10:25 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: pumpkins R orange (comp)
That looks dayum good IMO. I wish I would have thought to do something like that with mine when I had it out. Instead I just went with cast blast. Good job, I would not knock any points off on that. :thumbs:
Old Feb 11, 2004 | 05:20 PM
BDR68's Avatar
BDR68
The pumpkin is way too cool..:cool::cool: Now if you are really an old guy, from the 60's or 70's??? Paint the drive line Red and White "Barber Shop Pole" :D :D
Old Feb 11, 2004 | 05:49 PM
MN-Brent's Avatar
MN-Brent
Ive seen this done to the rear of an old black TA and man it looked beautiful. Kind of a gloss orange.
Its different-I like it.
Brent...
Old Feb 12, 2004 | 09:43 AM
GATOR454's Avatar
GATOR454
Default Re: pumpkins R orange (BDR68)
Here it is installed:
Bruce, I have vague recollections of the 70's and do remember seeing orange differential covers on jacked up muscle cars, but can't say I ever heard of barber pole drivelines. I like your thinking though and think it's a good way to knock off a few more pesky points. Maybe black and silver or black and orange spirals on the half shafts. Unfortunately I think my new VBP spring brackets will get in the way of the effect.
BTW I really like the my new VBP differential cross-member reinforcements. They really clean up that connection, and made reinstalling the differential and cross member much easier.
Also, before I reinstalled the differential I drilled four small pilot holes just above the location of the differential mounting bolts so if I ever have to drop the differential again I can drill some larger holes from the inside and remove the differential mounting bolts without dropping the cross-member. Then make an access plate to cover the larger holes.
Old Feb 12, 2004 | 09:52 AM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
I know that some dirt track cars had barber shop pole painted driveshafts...
Old Feb 12, 2004 | 09:55 AM
Stoge's Avatar
Stoge
:cool: :cool: :cool: :cool: :cool:
Old Feb 12, 2004 | 10:17 AM
Chumpzilla's Avatar
Chumpzilla
Looks damn good. What type of paint did you use?
Old Feb 12, 2004 | 10:28 AM
GATOR454's Avatar
GATOR454
Default Re: pumpkins R orange (Chumpzilla)
I painted it with the same stuff I painted the engine with, plasti-kote chevy orange engine enamel in a rattle can.
[Modified by GATOR454, 10:32 AM 2/12/2004]
Old Feb 12, 2004 | 11:26 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Yeah - some racing rules require the drive shaft be white. That way when you spit it out on the track the other drivers can see it. The barber pole stripe is just for fun.
Old Feb 12, 2004 | 11:30 AM
LemansBlue68's Avatar
LemansBlue68
How do you get the candle in it? :jester
Old Feb 12, 2004 | 12:35 PM
GATOR454's Avatar
GATOR454
Default Re: pumpkins R orange (LemansBlue68)
Eric, It took me a minute to figure out what the heck you were talking about. Then it hit me and I had to chuckle. :lol:
Maybe I should just paint the face on!
Old Feb 12, 2004 | 02:57 PM
JJ Deuce's Avatar
JJ Deuce
:cool:
Old Feb 12, 2004 | 03:02 PM
stinky's Avatar
stinky
David
I like it. By the time you get to zero points you'll be really happy with the way your car turned out :lol: BTW, how did you manage to thoroughly clean that third member to prep for painting? Mike
Old Feb 12, 2004 | 03:12 PM
verskel's Avatar
verskel
Nice ! :D ......wanna do mine ?!? :p:
Old Feb 12, 2004 | 04:21 PM
GATOR454's Avatar
GATOR454
Default Re: pumpkins R orange (stinky)
Mike, that's my goal 0 points. The third cross member on my car wasn't that bad. I sprayed it with degreaser then pressure washed it then scrubbed it with degreaser and a scotch brite pad. The only thing left after 30 years of grime was gone was bare metal. I used a long piece of sandpaper to get the top and hit the whole frame with every size wire brush known to man.
This pic is after the scrubbing:
Then I sprayed it all with por-15's metal ready, rinsed it then painted it with por-15, then after the paint had set for 3-5 hours I top coated it with rustoleum satin from a rattle can. I actually painted the entire underside, fiberglass and all, with the rustolem. The floorboards and front fire wall were then painted with Ace industrial aluminum paint to help reflect exhaust heat.
Verskel, sure no problem just bring it by.
[Modified by GATOR454, 4:23 PM 2/12/2004]
To pumpkins R orange
