which replacement oil pan do I need?
Old Feb 14, 2004 | 08:36 PM
Frankenvette's Avatar
Frankenvette
Default which replacement oil pan do I need?
My vette has a 1970 Camaro/Nova 350ci. I want to replace the oil pan in the near future but not sure which oil pan I need. My engine has the oil dip stick on the drivers side as all pre-79? engines. Did all stock chevy pre-79 engines with the oil dip stick on the drivers side use the same oil pan?
Old Feb 15, 2004 | 10:35 AM
marshrat99's Avatar
marshrat99
Default Re: which replacement oil pan do I need? (Frankenvette)
Summit has this Milodon one listed for $76. Part number is MIL-30700. It's a baffled, stock replacement. There are lots of other pans out there, depending upon what you're looking for. I suggest you just give Summit or Jeggs a call. Hope this helps. :cheers:
