What Tire Pressure ?
Old Feb 15, 2004 | 10:00 PM
MEAN72's Avatar
MEAN72
Default What Tire Pressure ?
What do you guys recommend as a tire pressure for normal street/cruise use? I have a 72 Convertible with an LS-5 and 4-Spd. I recently installed Fireston Firehawks Indy 500 tires, 235/60/15 front and 255/60/15 rear. I am running 32 psi in them but don't know what the optimum pressure is for good traction and uniform wear. What is your suggestion? :confused: :confused: :confused:
Old Feb 15, 2004 | 10:10 PM
Darrell's 68's Avatar
Darrell's 68
Default Re: What Tire Pressure ? (MEAN72)
I have a small block and I am running 28-30 psi with the same size tires. I have put about 20k on them and the tires still look great with no premature wear.
Old Feb 15, 2004 | 10:28 PM
trw's Avatar
trw
Light'em Up and see if you have a full tread pattern. :smash: :smash:
Terry
Old Feb 16, 2004 | 08:07 PM
MEAN72's Avatar
MEAN72
Thanks guys. I think I'll try 30 psi before I light em up :D :D :D
Old Feb 16, 2004 | 08:59 PM
gh78's Avatar
gh78
I run recomended air pressure thats on inside door panel, 28 psi in front and 32 psi in back.
Old Feb 16, 2004 | 09:05 PM
LiveandLetDrive's Avatar
LiveandLetDrive
Default Re: What Tire Pressure ? (gh78)
my door says 20/26.. mmm... don't think so. Really, you have to figure out what your contact patch is, as it will vary with car weight.
I have a question... what effect do tire sizes have on the necessary pressure?
Old Feb 16, 2004 | 09:07 PM
Pete76Shark's Avatar
Pete76Shark
Door sticker recommended tire pressure for my 76 seem low at 20front and 26rear
Old Feb 25, 2004 | 10:34 PM
MEAN72's Avatar
MEAN72
I got the number for Bridgestone/Firestone Technical Support Services (1-800-847-3272) and asked them 'what tire pressure?'. They were very polite and courteous but the best information I could get was a load vs. pressure table which they Faxed to me. I contacted Tire Reack and they told me I should run the recommended pressure for the car. My 32 year old car came equiped with F70-15 tires. My car placard and owners manual tells me to use 24 psi (cold) pressure in my tires. This seems way to low to me for modern tire design and oversized tires. Tire Rack tells me the prressure is based upon the car, not the tires. I believe this within ceretain modern bounds but not for a 32 year old car and tire design. :confused: :confused: :confused: I am going to run 30 psi in the tires and see what happens unless you guys can tell me different. Thanks for your help. Any further suggestion guys? :confused: :confused: :confused:
Old Feb 25, 2004 | 10:40 PM
MEAN72's Avatar
MEAN72
Default Re: What Tire Pressure ? (RUXperienced)
"what effect do tire sizes have on the necessary pressure? "
Tire Rack says none, even though the sizes have changed the car has not. They say that the air pressure is based on the vehicle and that we should still run the recommended air pressure for the car.
I am not a believer. I wouild think that 32 years of tire design changes would change the footprint to pressure ratio.
:confused:
[Modified by MEAN72, 3:42 AM 2/26/2004]
Old Feb 25, 2004 | 10:44 PM
Milest's Avatar
Milest
I have BFG Radial TA's 245 15 60s all around on my 72 small block, and found that 30-31 in the rear and 28 in the front was the best combination. 30 in the front made the car bounce a bit too much for my driving; which is just cruising with a little screech now and then.
Hope this helps.
Old Feb 26, 2004 | 02:24 AM
aharte's Avatar
aharte
There are a lot of factors that go into the OEM pressure recomendations, and it does have a lot to do with the specific tire on the car. Besides tire wear, the pressure also affects the various traction characteristics of the tires and also changes the ride. If you want performance, you should try different pressures, and see what you like. It can really change the feel of the car, and isn't dangerous unless you're really careless about it.
There's no possible table that will be anything more than a starting point. There's a lot of personal preference involved, as well as your specific alignment and suspension setup (and weight distribution of course).
Old Feb 26, 2004 | 06:50 AM
Sleper's Avatar
Sleper
Your tire pressure will depend on what your are trying to obtain with your car. If you are looking for best gas mileage and tire wear you should be running between 32 and 35psi as suggested on the tire. :blueangel:
If you run very low tire pressure you stand the chance of blowing a tire at highway speed on a hot day. :cry If you are looking for traction you should go to a abandoned lot and do a burnout and check for tire patch on the ground and then adjust until the patch is of even color and size (width) :D
I would suggest something between traction and reliability in the 30-32 psi range :thumbs: My $0.02 Personally I run 26 left side rear 28 right side rear and 29 in the two fronts. This give me best traction as well as with the staggered pressure my car takes of straight and the rear does not skate out to the right. :cool: If I run the highway to a car show I up the pressure all the way around to 34 psi. ;)
Old Feb 26, 2004 | 07:33 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
I'm running same tire - Indy 500 Firehawk but I have 255/60's all the way around. 35PSI is a bit of a harsh ride .... I run 32 all the way around at the moment.
Old Feb 26, 2004 | 07:35 AM
SanDiegoPaul
Default Re: What Tire Pressure ? (SanDiegoPaul)
The original recommendation for tires was based on Bias Ply rubber, not radials. That is the reason taht the pressure recommendation was so far off target.
:yesnod:
Old Feb 26, 2004 | 11:49 AM
MEAN72's Avatar
MEAN72
I talked with Tire Rack this morning and Firestone yesterday. I gained no knowledge except that no one in the retail tire business understands that tire design has changed in 32 years when we went from the original equipment F70-15 bias ply tire to the 255/60/15 radial tire I am now running. Sure, the car is the same and pounds per square inch can still hold up so many pounds (if the area is same) but they fail to realize that the link in between that has changed is the tire itself. The tire structure is entirely different. The sidewalls are more flexible. The belts within the tire are different, etc, etc.
I know that my placard calling for 24 psi is not right. I would hatre to take a hard corneer at 24 psi or run susained high speeds. Maybe I will drop the pressure down to 28 psi but no further. :steering:
Thanks for your help and suggestions.
Old Feb 26, 2004 | 12:35 PM
marshrat99's Avatar
marshrat99
For normal daily driving, ignore door stickers and other advise. For your safety and others, always use the tire pressures recommended and load ratings posted on the side of the tire. :cheers:
Old Feb 26, 2004 | 06:07 PM
Fang S-289's Avatar
Fang S-289
Default Re: What Tire Pressure ? (Pete76Shark)
Works well for me! :auto:
Old Feb 26, 2004 | 06:28 PM
Darrell's 68
Default Re: What Tire Pressure ? (Fang S-289)
Mean72,
I am running the same size tires as you and I keep the pressure between 28-30lbs. I have about 20k on the tires, and they are wearing well. I find that any more air pressure than that makes my ride quality fall off.
Old Feb 27, 2004 | 08:24 PM
MEAN72's Avatar
MEAN72
Default Re: What Tire Pressure ? (Sleper)
...you should be running between 32 and 35psi as suggested on the tire.
SLEPER,
The only pressures on my tires are a maximum presssure of 44 psi and a 40 psi maximum pressure for safety when mounting the tires. Neither is recommended for normal running, Is your pressure on the tire of 32 to 35 psi a maximum pressure or a recommended running pressure? :confused:
To What Tire Pressure ?
