Norval! Cool tool found: Adjustable Trailing arm jig.
Old Feb 16, 2004 | 05:38 PM
ZD75blue's Avatar
ZD75blue
Default Norval! Cool tool found: Adjustable Trailing arm jig.
Hey Norval...
Found something that might intrest you, or any of the other suspension gurus here on the forum... a jig for building trailing arms, so you can make more then one size and identical copys!
http://www.blindchickenracing.com/To...ng_arm_jig.htm
Heres the main part of the site... alot of other cool home made stuff: http://www.blindchickenracing.com/
:cool:
Old Feb 16, 2004 | 07:19 PM
ZD75blue's Avatar
ZD75blue
Default Re: Norval! Cool tool found: Adjustable Trailing arm jig. (ZD75blue)
Back ta the top... :cheers:
Old Feb 16, 2004 | 07:20 PM
norvalwilhelm's Avatar
norvalwilhelm
I looked at the jig ZD75blue but don't know how it would work in our case.
I have in some post described how to modify our stock trailing arms to make them clear any tire that fits inside the frame and you don't need a jig to do it. The trailing arm remains it's own jig all the way through the welding process.
Takes about an evening per arm.
To Norval! Cool tool found: Adjustable Trailing arm jig.
